First post, by Paul_V
UPD: I'm in the process of removing outdated/irrelevant info for the ease of reading.
Hello, everyone and happy holidays.
For a couple of months now I've been tinkering with a Vortex86DX boards to use for a retro rig.
While the rig is yet far from completion, I've gathered a bunch of info and personal findings, which I have not found posted elsewhere and decided to share.
I'll try to add info as the progress goes.
1) BIOS
Vortex86DX is basically a SoC, it can be crossflashed to almost any BIOS written for it, provided it has the nessesary videocard chip BIOS rom.
I have succesfully cross-flashed PCM-3343 (Which has AWARD bios with no disable L1\L2 cache capability) with AMI bios from PFM-535S, which share the same Lynx EM+ GPU.
You can also swap the GPU ROM modules with AWARD BIOS 6.0 \ AMIBIOS8 proprietary tools (e.g. to replace fixed resolution LCD rom with CRT)
I DO NOT RECOMMEND tinkering that way if you don't know what you're doing.
BIOS chip is integrated in the CPU itself, and in the case of failure you won't be able to recover without proprietary software and cabling.
All boards I own have proprietary JTAG connector to flash the BIOS, requiring a parallel xilinx cable and proprietary jflash.exe utility.
I've been using BIOSMP.exe utility from DM&P to flash and dump SoC BIOS with no issues so far.
2) CLOCK DIVIDER, CACHE REGISTERS, PLL LIMITATIONS:
CLOCK DIVIDER:
The PLL Clock divider register is well documented here (North Bridge Fun 0, Offset A0h, bits 0-2)
http://www.dmp.com.tw/tech/DMP_Vortex86_Serie … ence_091216.pdf
PLL Clock division can be set to 1/2/3/4/5/8/16 or 32. Datasheets mention some older revisions which may have 1/2/3/4/5/6/7 or 8
Can be changed on the fly with any PCI register editor or debug.
CACHE REGISTERS:
L1 Cache can be disabled from BIOS or by using existing x86 cache disabling utilities (CR0 register bit 30)
L2 Cache can be disabled from BIOS or by editing NorthBridge register:
North Bridge Function 1
Register Name: L2 Cache Control Register
Register Offset: E8h bits 0-1
BIT 1: L2 Cache Write back enable
0: write through
1: write back
BIT 0 :L2 Cache enable
0: disable
1: enable
DIVIDER PLL LIMITATIONS:
(Confirmed by ICOP)
Disabling L1 Cache effectively disables any PLL CPU division on DX/DX2/DX3.
(In practice DX can still use /2 division, but any value below that won't work)
Also, SoC cannot clock lower than it's current PCI bus speed.
3) CPU and DDRII HARDWARE CLOCK STRAPS
If cache disable and clock division options aren't enough for you, then it's time to dig deeper in the datasheets.
There are hardware straps on the SoC itself that you can use to set initial CPU\RAM frequency.
Two different datasheets can be found on the internet for the SoC. The first one in my case got the wrong data on the straps (maybe the were several revisions of CPU, idk)
The link below is what worked on my PCM-3343
https://www.vortex86.com/file?serial=Vortex86 … a_sheet_V200_BF
I've attached a brief table with strap configuration (does not cover all possible cpu values), as well as the location of the straps for the PCM-3343 (pins location on the CPU itself can be seen in datasheet)
The CPU pins for setting CPU clock are : C11,B12,B11
For setting RAM clock, the CPU pins are: A12, C10
A strap pin pulled-down with 4.7k resistor to GND is "0"
A strap pin pulled-up with 4.7k resistor to 1.8v VCC is "1"
No pull-up or pull-down on a pin is a tri-state "z"
For a different motherboard, you'll have to locate these pins and traces manually.
The traces may not even exist, if the manufacturer didn't need\design them, but there's a trick to identifying them:
1) Most of these strap resistors share the same pins on DX with RAM ICs. (e.g. MA10 strap elecrically share the same trace with RAM IC A10 pin, check with the datasheet).
2) Having a board with SoC\RAM frequency other than 800\400Mhz means there are definitely some strap resistors present.
The cross-flashed BIOS I got also had a hidden option "DDRII power saving" and DDR timings. It cuts the bandwidth of the RAM by about 25%
UPD 22.02.22:
Hardware strap info, benchmarks and other data will be poster and updated here:
https://docs.google.com/spreadsheets/d/1wEa2x … dit?usp=sharing
Reply 1 of 53, by snufkin
Paul_V wrote on 2021-12-29, 17:13:
1) BIOS First thing is rather obvious: as Vartex86DX is basically a SoC, it can be crossflashed to any BIOS written for it, pro […]
1) BIOS
First thing is rather obvious: as Vartex86DX is basically a SoC, it can be crossflashed to any BIOS written for it, provided it has the nessesary videocard rom in it.
A big leap of faith from my part, however. And I sertanly DO NOT RECOMMEND tinkering that way. BIOS chip is internal in this thing, and in the case of failure you're practically screwed.
All boards I own have JTAG to flash the BIOS, but I've yet to recieve a programmer to try tinkering with it, but my expectations are not high.
Just wondering if an external EEPROM can be used for the BIOS. The datasheet you linked says "The Flash could be disable & use external Flash ROM" and there's a Q&A on the Vortex86SX that says "You can use external flash as the BIOS storage, for example SST 39SF020-90-4C-PH, please pull-down the Hardware Strap MA12 and MA13 to enable the external BIOS flash.", from here: https://www.dmp.com.tw/tech/vortex86sx/faq.htm#1005
The pinout datasheet for the 86DX you linked to has pin F10 as Strap[12], defaults to internal pull up (BIOS on internal SPI), pull low for 8-bit flash, and pin G21 is a ROM chip select pin which might be involved (but might be to with boot ROM rather than BIOS).
Unfortunately it doesn't seem to give any more information about how to connect an external ROM. Given they won't give any information about the JTAG programming interface then they probably won't help with this either.
All seems like a lot of work with a lot of guesses so no great expectation of it working.
I did find what looks like am more complete datasheet for the 86EX in case it's any use, but it seems to get it's BIOS from the PCI bus:
https://www.86duino.com/wp-content/uploads/20 … V14_86duino.pdf
1. High BIOS Area (FF00_0000–FFFF_FFFFh) The top 16 Mbytes of the Extended Memory Region is reserved for System BIOS (High BIOS) […]
The top 16 Mbytes of the Extended Memory Region is reserved for System BIOS (High BIOS),
extended BIOS for PCI devices, and the A20 alias of the system BIOS. The CPU begins execution
from the High BIOS after reset. This region is mapp ed to the PCI so that the upper subset of this
region is aliased to 16 Mbytes minus 256 Kbytes range.
Reply 2 of 53, by Mumak
I have been working with these systems a couple of years ago for a company I worked for. Have some datasheets but most are watermarked, so can't release them.
There are also BIOS images (for VDX-6390 EVB) and other design stuff like sch... Not sure what would be of interest here.
Reply 3 of 53, by Paul_V
snufkin wrote on 2021-12-29, 21:26:
Just wondering if an external EEPROM can be used for the BIOS. The datasheet you linked says "The Flash could be disable & use […]
Vortex86SX supports 16-bit flash, while Vortex86DX supports only 8bit, while having 16-bit flash integrated. DM&P support claims almost no one uses external SPI for BIOS.
PCM-3343 does have an unsoldered pads for external spi flash along with some missing components, but I was unable to locate the traces for the strap that switches the cpu to use external chip (had to resort to services of an x-ray machine to find cpu\ram strap traces). And I honestly don't know if 16-bit and 8-bit BIOS chips are interchangeble. This external chip is mostly used as a virt. floppy boot device.
Considering JTAG, I'm quite sure it's wiggler-type parallel interface cable. The only question is the utulity used for flashing. And the company, which mentioned "jflash" utility in their manual is, unfortunately, long gone.
Advantech has a couple of similar utilities, for the intel StrongARM and Xscale based cpus. A pretty long shot, but i'll try to tinker more, when I find time to bodge a parallel cable.
Until then, I'm pretty limited on the amount of experiments I can do on the BIOS. Pushed my luck pretty hard twice already.
https://www.advantech.com/support/details/manual?id=1-DDI4J
Mumak wrote on 2021-12-29, 22:00:
If you could provide a dump, I would be most grateful. Vortex86 BIOSes are hard to come by. They also often have a ton of hidden options.
I'm currently awaiting VDX-6354RD to play with and to compare.
Reply 4 of 53, by Mumak
Here you go.
The attachment DX A6 BIOS.7z is no longer available
Reply 5 of 53, by Paul_V
Mumak wrote on 2021-12-29, 23:34:
Here you go.DX A6 BIOS.7z
Much obliged! Certanly will look into it and post, if I find something interesting.
Reply 6 of 53, by Paul_V
Apart from having different external LAN rom and less hidden options, VDX-6390 BIOS seems almost identical to the AMI BIOS the PFM-535S has (PFM-535S has more options, but they are useless in terms of underclocking).
I think most of the Vortex86DX OEM motherboard manufactures have just been swapping these roms with minimal modifications, hiding unnecesary options, with the exception being Advantech with their own AWARD 6.00PG BIOS
I've found a reference manual for the AMI BIOS, which covers almost all capabilities (with the exception of north bridge options and some others).
Interestingly, the manual clearly shows CPU divisions from 1 to 8, so there's definitely been a SoC revision change, as the division is controlled by the north bridge register.
http://ftp.emacinc.com/LegacyProducts/S ... _v1r0A.pdf
Also, AWARD BIOS makes utility like FDAPM detect APM 1.2 cabablities, while AMI not.
The only half-working options FDAPM could do is enter suspend and stanby, which it could not not wake up from. No luck throttling this way yet.
The best downclock results so far, which make Planet's Edge somehow playable:
500Mhz CPU strap with /8 divider = 62,5Mhz (/32 divider makes no difference, apart from making BIOS menu keystroke lags)
L1/L2 disable
Unlocked AMI BIOS option - DDRII Power Saving Mode (Active/Precharge)
I've soldered an additional pull-down resistor to downclock RAM from 300Mhz to 266Mhz and updated results in the first post.
The results are negligible at best. I have a feeling i'm missing on something.
In theory, i'm still about 30Mhz away from the absolute minimum this CPU can operate. In datasheet, there is a note that a CPU cannot clock lower than it's bus speed, which is 33Mhz. And this is the indirect proof that /16 and /32 dividers do something else. 800/32= 25Mhz, which is well below that threshold. Makes me wonder if overclocking the CPU to 1066Mhz and then choosing /32 option will work any different (probably not, as x16 on a 800Mhz did not result in 50Mhz by timestamp measurement).
Anyway, from now on I'll need to find a way of reliably soldering some wires or connectors to the tiny 0402 pads without fearing them being torn in the process.
Otherwise, constant resoldering and reconnecting will put too much stress on the board.
Reply 7 of 53, by Paul_V
I've got my hands on a ebox-3300 mobo and have successfully identified CPU and RAM straps on it (R5/R6; R7/R8; R9/R10; R11/R12; R13/R14 - are the pullup/pulldown resistors on the mobo, I'll post more details later).
It defaults at 933Mhz CPU and 300Mhz RAM. (This configuration requires a total of three pull-down straps, which made identifying them much easier)
It has more soldering-friendly 0602 type smd pads, so I think I'll use this motherboard to solder test switches and run benchmarks.
It does not qualify for me as a retro-rig due to the absence of an ISA(PC/104) slot, but can provide tons of useful data .
I've already begun identifying which straps are for CPU and which are for RAM. I've pulled R5/R6 high by soldering 4.7k to R5.
It turned to be STRAP-4 for RAM, which downclocked it from 300Mhz to 166Mhz, perfectly matching the datasheet.
Switching RAM to 166Mhz and applying all other downclocking vo0doo stuff on a default 933Mhz CPU strap setting, I was able to achieve a score of 49 in TOPBENCH.
Even Wing Commander runs somehow sluggish now.
There's also another pitfall with BIOS flash utilities.
To unlock some options, I've dumped original ebox-3300 BIOS using BIOSMP (original DMP utility) and SPIFLASH (which was in the archive with BIOS kindly provided by Mumak).
The sheer volume of the BIOS chip is 2MB (hence, the dump is also 2MB), but the BIOS image itself is 256KB.
2MB dump is uneditable in AMIBCP, so I had to manually cut empty space of the dump in hex editor for it to match.
Moreover, SPIFLASH dumped only empty space, which resulted in a 1835008KB dummy file filled with FF's.
Pushed my luck once more, now I have all the options I need.
Currently, I'm filling a table with benchmark results using TOPBENCH.
Some stuff turns out to be pretty interesting. I'll publish the results when I complete all possible combinations with this motherboard.
Here's the short summary of currently available options on Vortex86DX, making it the most versatile hardware piece I've ever had:
1) HW straps to clock CPU from 500Mhz to 1000Mhz (may be lower/higher, but needs testing. datasheet mentions speed sync to RAM and clocks up to 1500Mhz)
2) HW straps to clock RAM from 166Mhz to 400Mhz
3) L1/L2 Cache (L2 cache control currently available only as an AMI BIOS option, no utility yet)
4) CPU clock division 1/2/3/4/5/6/8 (/16 and /32 division usefulness are questionable at the moment - I have theories and need more tests.)
5) DDR II Power Saving Modes Active\Prefetch
6) Memory timings (CAS range from 2 to 5 CLKs; tWR from 1 to 7 CLKs;tRP from 1 to 15 CLKs; tRCD from 1 to 15 CLKs)
P.S.
Setting RAM speed to 166Mhz did not seem to cripple Nascar Racing 1\2 performance very much.
So soldering just the resistors as the final solution for the versatile retro-rig is still a viable option.
Don't want to end up with a retro-rig dosbox sim with a ton of switches.
Reply 8 of 53, by debs3759
Paul_V wrote on 2022-01-09, 22:19:
The sheer volume of the BIOS chip is 2Mb (hence, the dump is also 2Mb), but the BIOS image itself is 256kb.
Did you mean 2Mb and 256KB? 2Mb = 256KB. Small b is bits, large B is bytes.
Reply 9 of 53, by Paul_V
debs3759 wrote on 2022-01-09, 23:18:
Sorry, my bad. I mistyped the values, it's MB and KB, of course. The flash chip is 2MB and the BIOS image is 256KB. I'll make corrections to the post above
Reply 10 of 53, by debs3759
It's an easy mistake. I didn't always know there was a difference 😀
Reply 11 of 53, by Paul_V
Some preliminary results:
I've chosen Topbench as a primary reference tool, Doom min\max benchmark from Phil's benchmark compilation as a secondary reference and internal timestamp counter from chkcpu beta.
The particular interest is the behaviour of the CPU (or I should better start calling it SoC), which is counter-intuitive. (I've omitted the rest of BIOS settings benchmarks on the screenshot for the time being)
CPU divider setting works "almost" as intended, while the L1 cache is on. (I'm still positive, that timestamp counter will show adequate numbers on bothD/16 and D/32 if I overclock the CPU to 1066Mhz first).
But, as soon as L1 is disabled, all divider settings below D/2 become negligible, or have no effect at all. 0_o
Reply 12 of 53, by Paul_V
Small update:
A link to a document (containing hardware stap info, benchmarks, etc), which I'll be updating as I go.
Current progress is somewhat slow due to various reasons and I'm yet to devise a way of safely soldering hardware strap switch.
Reply 13 of 53, by Paul_V
A small update concerning BIOS and motherboard un-bricking:
Eventually, I was able to boot from external ISA\EEPROM 8bit flash BIOS.
The main trick is that the SoC pin 'F10', which you need to pull low is also an address pin A12 of the DDR2 memory ICs.
A12 is easily accessible due to it being on the outside (see pic below, I inserted a cable between A12 and NC ball pins VERY CAREFULLY, as the Vdd pin is nearby and used a 10k pull-down resistor). Moreover, if your motherboard does have some unsoldered memory IC's pads, it becomes even easier.
I've made a simple pc/104(ISA) to EEPROM adapter, flashed a 29EE020 chip with AMI Bios
Then, pulled the A12 low (any memory chip will do, as these pin runs in parallel).
But now I found myself in a predicament. I cannot seem to flash internal SPI flash when having system booted from ISA.
The only difference I could find is PCI register 61h, which is read-only and not listed in datasheet.
I'll try some other tools, but it seems that internal SPI is disabled for good when booting from ISA.
So, this method may not be viable in terms of restoring the original BIOS... bummer. 🙁
Also, I'm somewhat disappointed in a way AMIBIOS8 has been implemented on these boards. AMIBIOS Core 8 bootblock has at least four methods of recovering main bios block: floppy\ATAPI\USB\Serial.
None of them are implemented on ICOP boards. Others have floppy recovery working, probably just because it's a default option they did not turn off when building an image.
Floppy recovery on my boards is useless, as they do not have floppy connector (some others do have a floppy implemented through external super i/o chip)
Besides, onboard sketchy floppy SPI emulation makes recovery procedure think a floppy is already present and tries to search for BIOS file in a void.
All I could do is connect external SPI and format it using SPITOOL.
But could not mount it as a floppy nor copy BIOS file to it. Probably lacking the proper driver in BIOS.
But a least now I'm somewhat able to experiment with BIOS freely without giving everything "RMA seal of approval".
UPD:
Some BIOS'es seem to corrupt the image by overwriting some area with data after first boot if I let the bus handle OE# and WE# signals of the chip.
If I put the chip manually in read-only mode, everything's fine.
My theory is that some BIOS'es save data into FRAM or similar (Both Advantech AWARD and EBOX AMI version have an option to save settings, which persist even without a battery)
So, when you disable SPI and boot from ISA using exact same BIOS image, it probably corrupts itself trying to write data to the wrong address.
Reply 14 of 53, by componentswitcher
wait so you added isa, could you add a sound card then?
Reply 15 of 53, by Paul_V
componentswitcher wrote on 2022-05-08, 20:09:
I did not "add" an ISA slot, so to speak. I merely switched the board to seek BIOS code on it's ISA bus, instead of SPI.
The board itself already has an ISA slot implemented, just in another form-factor (PC/104)
So, yes. The sound card (and any other ISA device) can be added, either using diy or industrial PC/104-to-ISA adapter, or designing your own PC/104 format sound card.
Which has already been done by many.
But if you meant that i've used up a slot, which could be used for a soundcsard it's not a problem either. You can stack these either at the bottom or on the top side of the PC104 socket.
A very crude implementation of the adapter below, but it works and gave me alot of insight on this SoC. Additional BIOS chip can easily be added on top of the board in this buid.
Topic 87065
Reply 16 of 53, by rasteri
if someone could write a programm that could detect both L1\L2 cahce and disable them as needed, that would be awesome
Are you still looking for a tool like this? I'm about to do some more vortex86 experiments and will develop such a tool if it's still necessary.
I want to build a (probably) launchbox-based system to run different games and it would be useful to be able to adjust performance settings on a per-game basis.
I can't find any info about the cache registers in any datasheets but I have ICOP's ear so I might be able to find out what they are.
Reply 17 of 53, by Paul_V
rasteri wrote on 2022-05-15, 14:06:
Are you still looking for a tool like this? I'm about to do some more vortex86 experiments and will develop such a tool if it's […]
Hi, rasteri! Thanks for stopping by )
I had an idea to find that register by comparing debug utility output of CPU's registers with cache turned on\off in BIOS, then making a simple batch file.
Never did try it though, as the cross-flashed AMI BIOS with unlocked options did cover almost all of my needs.
Still, this SoC is pretty darn fast for some games even with all my performance crippling voodoo.
The things that bugs me the most by now is JTAG BIOS flashing.
I planned to try something like openocd, but currently lacking free time to do so.
Reply 18 of 53, by Paul_V
Small update.
I'm uploading a brief schematic on how to connect and boot from ISA EEPROM, in case someone would need it.
Note, that there are some complications using original BIOS image meant for SPI.
I spent some time trying to underclock this SoC further with mixed results.
When using strap option mentioned in the datasheet "SYN DISABLE. CPU clock same as DDR", the board BIOS POST fine and detects all drives,
but is unable to boot from any of them, ending with just a blinking underscore. I observed similar behavior trying running CPU at 1066Mhz
Maybe I'm missing a step there, or maybe it's just a sketchy datasheet and that strap configuration was never meant to be used.
Reply 19 of 53, by Paul_V
Another small update:
Good news:
I've been able to track down the software used to flash Vortex86DX internal BIOS through JTAG port.
Also, found another datasheet, which is more comprehensive in terms of register control and functions (including L1\L2 cache control)
So, writing the cache and divider control utility is definitely possible.
Bad news:
Not sure if it's legal to post them here. Probably not (watermarked) 🙁
Also, I had no luck yet flashing one using this tool. It resets the CPU, but RDID command keeps getting random data about the flash chip ID and refuses to proceed. Quite a lot of options of getting things wrong here:
1) Wrong parallel cable configuration (awaiting parts now to build a genuine buffered xilinx iii cable)
2) Wrong host parallel port configuration \ PC too fast
3) Disabled JTAG on the motherboard (At least I think I tracked the right pin on my motherboard and enabled JTAG without frying something)
4) Got the wrong utility
5) I finally fried something, my brains included
