First post, by ante1234and
hi
is there any way to get this game working correctly? when i finish a level and that scene showing the winner appears, i press enter to choose another stage but instesd the game shuts itself down to the dos prompt.
what should i do to fix this? i have 645 mb of expanded memory in dos or does the game require extended memory or something else?
the specs are this:
pentium 3 500 mhz
384 mb ram
soundblaster 16 isa card
nvidia tnt2 m64 graphics card
Reply 1 of 3, by Disruptor
Have you tried it in DOS window or in real DOS?
Do you run it in CGA or EGA mode?
(It does not support soundcards, just PC speaker)
Perhaps something with your copy is wrong...
Reply 2 of 3, by ante1234and
Disruptor wrote on 2021-12-24, 15:20:
Have you tried it in DOS window or in real DOS? Do you run it in CGA or EGA mode? (It does not support soundcards, just PC speak […]
i've tried both running in windows and dos.
upp don't have a copy, i downloaded this game years ago from some website
Reply 3 of 3, by carheerwagen
We don't support abandonware. Get the physical copy and then this forum will help.
