First post, by GabrielKnight123
I have a new motherboard I'm testing before I put all my hardware in it so first things first I need to test the voltages are good for 5 volts from the motherboard socket for the socket 3, I have the pinout for the socket 3 and I'll be using an Intel overdrive DX2OPDR66 SZ935 that uses 5 volts. I need to know which pins on the socket 3 to test for 5 volts (row and number) to make sure its outputting 5 volts +- 5% do I test every VCC or does the DX2OPDR66 CPU draw from only one VCC as I cant find a pinout for the CPU. My next question is about the motherboard I'm using its a VL/I-486SV2GX4 Rev 2.0 and in the manual for jumper JP32 and JP33 it does not have a 5 volts jumper setting it has 3.45, 3.6, 4, 3.3 volts and my motherboard does not have JP33 it only has JP32 so as you see I don't know how to set the voltage on this board to 5 volts for the CPU above and I'm not sure it supports 5 volt CPU's even though its a socket 3
