Hello to everybody here! […]
Nearly four month ago, Skalabala got in touch with me at my thread about my GA-5AX on overclockers.com and drew my attention to this contest here. I totally forgot that I also created an account here at vogons.org more than four years ago... 🙄
I read this thread and it's all about GeForce 3 (mostly) graphics card and most recently a Voodoo 5 on SS7 platform. I always preferred ATi cards because
1. after 8 years of working/playing on my AMD N80L286-16/S from 1990-1998, my second PC (Intel Pentium II 400 MHz) was equipped with ATi 3D Rage Pro AGP (8 MiB) "assisted" 😉 by Voodoo 2 (12 MiB)
2. ATi always had better support for DVD playback.
Now, led me introduce one of my Super Socket 7 systems first:
- Gigabyte GA-5AX [Rev. 5.2; ALi Aladdin V (Rev. H)]
- BIOS F4
alternatively: BIOS F5 Powered by Lotosdrache
- 512 kiB onboard Cache
- AMD K6-2+/570ACZ@600 (6*100 MHz)
- 2x 256 MiB Mircon Technology SD-RAM PC133U-222-542-Z (MT16LSDT3264AG-13EE3)
alternatively: 3x 512 MiB SD-RAM (vendor: Micron Technology or Xelo)
- 3Dfx Voodoo3 3500 TV incl. breakout cable
alternatively: Matrox G400 Max
- Matrox m3D
- 3Com 3CR990-TX-97
- Terratec EWS64 XXL (Rev 1.2)
- Gravis Ultrasound Max (Rev 2.1)
- IDE-HDD: Maxtor 6Y080P0 (80 GB), Maxtor 4R060J0 (60 GB)
- IDE-ODD: Kenwood UCR-421 True-X 72x, HP CD-Writer Plus (don't know the exact model number)
- 3.5" and 5.25" floppy disk drives
That's how the system is intended to look like when it's finished. For this contest however, I will make a little change: I havn't got any GeForce 3 in my collection because GeForce is sooo mainstream. How boring! So, I looked through my stock and other systems and found a graphics card that should be equivalent to Geforce 3 considering time, features and performance:
ATi FireGL 8800 that found its way to me in an IBM IntelliStation M Pro (Pentium 4 with Rambus RAM) 😀
As you can see, this combination is suffering some problems:
1. Although the chipset revision is H and supports internal tag RAM, Gigabyte still used an external one. The internal tag is deactivated. Therefore, it can only cache 128 MiB.
Solution: I reverse-engineered the BIOS and injected a patch that
a) disables external tag RAM,
b) enables internal tag RAM and now the board caches 512 MiB of RAM,
c) modifies a number of other chipset register settings:
- SDRAM Trc=7T (8T before) and Tras=4T (5T before)
- SDRAM Internal Page detection enabled
- SDRAM Enhanced Page Mode enabled
- LINEAR_WORD-Merge for Frame Buffer Cycle disabled
- Fast NAJ asserted in single write cycle enabled
- SDRAM tRP=2T@FSB100 (4T before)
- AGP Control Register II: Output delay control of AD_STB[1:0] : Default-1nsec=2,5nsec
The following chipset parameters were changed with modbin:
- Separate setting for Trcd and CL enabled
- Trcd=2T select when bit6 = 1 enable
These last two changes have no effect on RAM timings at all. They are just of cosmetic nature 😉
Now, the chipset programming of my Gigabyte GA-5AX resembles Asus P5A nearly 😀
2. ATi FireGL 8800 is a workstation card and there are no drivers for consumer Win98SE/2000/XP.
Solution: I modified the inf-file of Catalyst 6.2 Win98SE driver and installed the card via device manager:
3. I saw that most of you had big problems to get ATi cards running on Aladdin V boards. My first trial on Thursday was a debacle, too. As soon as the system finished rebooting after driver installation, I could not open any program. Windows 98SE crashed immediately.
Solution: I had to limit Primary Frame Buffer Size to 16 MiB!
a) If you prefer using the original Microsoft Windows 98SE AGP driver then you must go into your BIOS-Setup -> Chipset Features Setup -> Primary Frame Buffer -> 16 MB
b) If you like to use ALi AGP driver (version 1.72, 1.82, 1.90, or 2.13 it doesn't matter) there is no need to change your BIOS setting. You can also use ALi AGP Control Center (aka ALi AGP Utility 1.40):
- click Smart Selection "Turbo" -> Apply
- go to "Manual"
- set "Frame Buffer Size" to 16M -> Apply
The other options (except AGP and SDRAM Delay Clock) have no effect on stability at least on my system. Frame buffer must be limited before Catalyst 6.2 installation. That's all. 😀
With this setting, FireGL 8800 runs absolutely stable albeit I only tested 3DMark2000 v1.1 with original BIOS F4, original MS Windows 98SE AGP driver, DirectX 8.1b, and ATi Catalyst 6.2 so far. The result was really disappointing:
BIOS F4
__________MS Win98SE____ALi AGP driver
___________AGP driver______1.72______1.82______1.90______2.13
128 MiB
DirectX 7.0a-------2900----------3019--------2845-------2979--------2837
-------------------------------------------------------------------(with 256 MiB: 2475)
-------------------------------------------------------------------(with K6-III+/400ATZ@550: 128 MiB=3441
------------------------------------------------------------------------------------------256 MiB=3257)
512 MiB
DirectX 7.0a-------2439----------2513--------2445-------2440--------2489
128 MiB
DirectX 8.1b-------2940----------2883--------2987-------2801--------2881
512 MiB
Directx 8.1b-------2482 🙁--------2460--------2469-------2537--------2474
-----------------2410----------2400--------2496-------2461--------2512
128 MiB
DirectX 7.0a-------2891----------2822--------2856-------2807--------2912
512 MiB
DirectX 7.0a-------2834----------2858--------2866-------2872--------2811
128 MiB
DirectX 8.1b-------2823----------2873--------2906-------2846--------2930
512 MiB
DirectX 8.1b-------2879 ----------2820--------2923-------2910--------2911
-------------------------------------------------------------------(onbord L2=L3 cache off: 2527)
-------------------------------------------------------------------(1 GiB RAM with MS files: 2474
--------------------------------------------------------------------1 GiB RAM with Rudolph Loew patchmem: 2837)
You see there is lot's of work considering BIOS and chipset settings, AGP and graphics card drivers, RAM capacity, DirectX version...
I will continue to fill this "table" (How can I create a smarter one?) from time to time. First, I have to look for better cooling of AGP voltage converter (it's getting really hot) and CPU (there isn't even heatsink paste between cooler and cpu).
I've got absolutely no idea where this journey ends up. Stay tuned!
Last questions to you:
How often do you loop the benchmark with the aim of cache training?
Are your systems fully equipped with sound cards, network interface cards and so on or do you use minimal configuration with only a graphics card installed?
EDIT 1:
I finished benchmark run with original Gigabyte BIOS F4 (see table above). I did most of the runs only once and that with 512 MiB RAM and DirectX 8.1b twice. However, I think I can make/confirm following remarks/statements:
1. The result range is considerably high. My estimation for a given configuration is: average +/- 50 points. Therefore it's hardly possible to declare a winner.
2. The differences between both DirectX versions are small (128 MiB / 512 MiB):
- DirectX 7.0a: 2923.2 / 2465.2
- DirectX 8.1b: 2898.4 / 2470.1
- Δ..................... -24.8 / 4.9
3. The differences between all 5 drivers are small (128 MiB / 512 MiB):
- M 98SE: 2920 / 2443.7
- ALi 1.72: 2951 / 2457.7
- ALi 1.82: 2916 / 2470
- ALi 1.90: 2890 / 2479.3
- ALi 2.13: 2877 / 2491.7
4. 128 MiB RAM are much faster than 512 MiB RAM (256 MiB RAM gave similar results as 512 MiB):
- 2910.8 <-> 2468.48
- Δ -442.32
5. K6-III+/400ATZ@550 MHz (5.5*100 MHz) is much faster than K6-2+/570ACZ@600 MHz (6*100 MHz) albeit a little bit more unstable (128 MiB / 256 MiB):
- K6- 2+: 2837 / 2475
- K6-III+: 3441 / 3257
- Δ............ 604 / 782
Therefore, more on-die cache is more helpful than higher clock.
6. With K6-2+/570ACZ@600 MHz on GA-5AX, I hardly achieve 3000 points with FireGL 8800 and standard chipset configuration 🙁
To comments about ALi M1541 AGP driver that drove me crazy:
1. Version 1.72 doesn't enable SDRAM Internal Page Detection (Offset 49/ Bit 1) when set to Turbo Mode as newer versions do.
2. All versions disable Force Snoop INV (Offset 43/ Bit 7) upon installation on this board (it's enabled by default through Gigabyte's BIOS) and enable it again after installation of graphics card driver.
To be continued...
EDIT 2:
I finished testing of my BIOS patch:
1. Differences between both DirectX versions are small again (128 MiB / 512 MiB):
- DirectX 7.0a: 2857.6 / 2848.2
- DirectX 8.1b: 2875.6 / 2888.6
- Δ...........................18 / 40.4
3. The differences between all 5 drivers are small again (128 MiB / 512 MiB):
- M 98SE: 2857 / 2856.5
- ALi 1.72: 2847.5 / 2839
- ALi 1.82: 2881 / 2894.5
- ALi 1.90: 2826.5 / 2891
- ALi 2.13: 2921 / 2861
4. 128 MiB RAM are no longer faster than 512 MiB RAM:
- 2866.6 <-> 2868,4
- Δ 1.8
From this I can conclude that
- the patch works and the board is now able to cache 512 MiB of memory with its internal tag RAM 😀
- decreased results with original BIOS F4 are possibly due to smaller cacheable area
5. Onboard L2 cache (= L3 cache with K6-2+) still impacts performance even with K6-2+ and its internal L2 cache
When switching onboard cache (=L3 cache with K6-2+) off, I only got 2527 points.
6. Upgrading RAM to 1 GiB decreased performance again:
- 2474 -> Here I am again out of the cacheable area with MS Win98SE original files.
Interestingly, using Rudolph Loew's patchmem files for systems with more than 512 MiB RAM kept the result high:
- 2837 -> Either the patch limits the system to the lower cacheable 512 MiB, or it reprograms Win98SE to fill the cacheable area first. I don't know.
All in all:
- DirectX 7.0a seems to be less stable on this system than DirectX 8.1b. At least, I got more abnormal terminations with version 7.0a than with 8.1b.
- With the new BIOS, the system seems to be a little bit slower than with the older one albeit of faster RAM timings. At least, I never reached 3000+ points as I did once before with 128 MiB RAM.
Therefore, I have to check whether SDRAM Enhanced Page Mode is really so enhanced. I tested 4 CPUCLKs here. Other settings are 8, 12, or 16 CPUCLKs. However, I never saw a board where this is enabled. Maybe I will disable it again. For this tests I'm going to use a Matrox G400 Max...
