majestyk wrote on 2022-01-01, 19:37:
Correct - according to the manual there is the "SCSI Selest" settings menu accessible at startuup with Ctrl-A as usual.
Yep ! The previous user may have disabled the BIOS if it was used just for CDROM, ZIP, JAZZ, tape drive, etc as the BIOS is only needed if using it to boot from.
"SCSISelect User's Guide >> Advanced Settings >> Host Adapter BIOS
This option enables or disables the host adapter BIOS. The default setting is Enabled. If the user is booting from a SCSI disk drive connected to the host adapter, the BIOS must be enabled. The user should disable the host adapter BIOS if the peripherals on the SCSI bus (for example CD-ROM drives) are all controlled by device drivers and do not need the BIOS. "
I would clean the edge contacts and pull the ROM and clean the pins with ISO alcohol just to make sure.....
