First post, by jheronimus
I'm trying to set up the drivers for the onboard sound chip on my Chaintech motherboard, but no matter which drivers I try, they don't actually get installed — the sound card stays marked with a yellow question mark in Device Manager saying that the driver is not installed.
I've tried both 6.44 drivers from Phil's website and 6.39 from Vogonsdrivers. I'm running setup.exe in either case, follow the procedure until it prompts for reboot and then nothing. I'm using Windows 98SE and I've tried a clean reinstall 2 or 3 times.
I've tried Windows XP and the drivers work out of the box, so I can confirm the chip is functioning. Audio is enabled in BIOS although "legacy audio" option is disabled as I'm also using an AWE64 in this motherboard.
Could it be that the onboard chip needs different drivers than dedicated soundcard with the same C-Media chip? Ideally I want WDM drivers, but at this point I'm fine with whatever.
Otherwise the specs are:
Pentium 3 1.4GHz
512MB RAM
Abit GeForce 4 Ti4200 OTES
3COM 3C905 NIC
AWE64 Gold
MR BIOS catalog
Unicore catalog
Reply 1 of 3, by Tiido
This particular board has a flaw, the 14.318MHz clock is missing on ISA slot and any card needing it will not function unless a modification is done :
239.87 KiB
CMI8738 cards I have all need the clock from ISA to be present so this should be the problem why things do not work.
Reply 2 of 3, by jheronimus
Tiido wrote on 2022-01-04, 02:18:
I’ve read about that issue in regards to AWE64, but my Gold works without any problems (I didn’t do the mod).
Also the CMI chip works under WinXP.
And besides, wasn’t that chip used on a bunch of PCI soundcards and non-ISA mobos? Seems unlikely it would rely on ISA
MR BIOS catalog
Unicore catalog
Reply 3 of 3, by Tiido
Whoops, I mixed it up with the ISA CMI8330, my bad.
