First post, by CraigAB69
Can someone please recommend a MB with hardware pass-thru and virtualization (IOMMU and VT-x / AMD-V.)
Something maybe 2 or 3 years old.
Also, what hardware are you passing through to the VM and which VM software are you using?
My primary use is programming (Assembly and C/C++) and system debugging.
Although, being able to run old games every now and then, would be cool.
Current system:
HP Envy M6 (2011)
16 Gb RAM
1 TB SSD
VirtualBox 6.1
Arch Linux
Regards
“Wyrd bið ful āræd. Fate is inexorable.”
