First post, by Jccwu
Hello colleagues.
Bought this card a few months ago.
This card has a problem, namely, the right channel does not work for it. I can only hear sound from the left channel with headphones.
I changed LF353 and NEC D6376 but it had no effect.
How to correctly diagnose the card in order to understand where its malfunction is?
20211229-225405.jpg 20211229-225410.jpg 20211229-225418.jpg 20211229-225423.jpg
Sound card's music
Reply 1 of 4, by Tiido
Do other WB cards work correctly on the sound card you attached this one to ? It looks like you already checked all the passives and probably found all to check out and since you swapped the DAC and opamp there isn't much more left that can be bad besides host sound card having a problem in one channel. If LRCLK wasn't pulsating then the DAC wouldn't output anything at all so the problem shouldn't be with the sound chip side or on the WB card itself.
Reply 2 of 4, by Jccwu
This board has been tested on several sound cards. The problem is in the daughter board
Sound card's music
Reply 3 of 4, by Tiido
Ok, then do a test where you connect DAC output pins directly to the WB header outputs (first separating the existing opamp circuit output), there should be sound and possibly quiet one but if even then one channel is missing it may be that the sound chip itself is bad and not actuall outputting one of the channels... 🙁
Reply 4 of 4, by Jccwu
just unbelieveble! I bought another one of the same card, and the right channel does not work for this card!
Now I have two cards with one working channel!
Sound card's music
