First post, by Plasma
Apparently this was a thing...
The motherboard is for a Siemens Scenic 620.
Reply 2 of 19, by Sphere478
mwdmeyer wrote on 2022-01-13, 05:17:
🤣, but why?
Because they could apparently… looking at the computer there doesn’t seem to be anything preventing normal orientation…
Sphere's PCB projects.
Reply 3 of 19, by Doornkaat
This allows cards with a PCB that's taller than the PCI bracket to be installed into a rather flat desktop case that's barely taller than the PCI brackets.
You save vertical space by sacrificing horizontal space.
Reply 4 of 19, by Horun
🤣 I think some on April Fools Day did this end of shift just to be ..... foolish ;p
Reply 6 of 19, by waterbeesje
Another thing i can imagine is to allow better heat dissipation from demanding cards. Not sure if this ever was a thing with ISA, but who knows 😀
Stuck at 10MHz...
Reply 7 of 19, by imi
Doornkaat wrote on 2022-01-13, 05:56:
"what are riser cards?" 😁
Reply 8 of 19, by snufkin
cyclone3d wrote on 2022-01-13, 06:35:
They had to put their slant on PCs...
Ow.
It's odd because the extra height of the connector means the angle doesn't actually save any vertical height (plus there are full height vertical cards as well) and just makes the case wider. Maybe they had an internal argument about whether to go with a riser card or not, and decided to compromise. But I like the way they've committed to it and even included the support at the front of the case for full length cards. Maybe it made it easier to get to headers/jumpers without having to take cards out. Slightly disappointed that I can't find any connectors like that.
Reply 9 of 19, by Doornkaat
imi wrote on 2022-01-13, 14:45:
Unnecessarily expensive compared to this simple yet effective solution. "It ain't stupid if it works."😉
Reply 12 of 19, by Big Pink
Well that answers the mystery of the odd Socket 370 board I kept seeing listed on eBay. I thought it was a rolling-shutter artifact at first.
I thought IBM was born with the world
Reply 15 of 19, by creepingnet
Never seen them deliberatley angled like that, but I Did have an HP Firebird Socket 370 for awhile with a Celeron 500 installed that had one of the PCI slots cantered to the side in that direction a little bit...but not anywhere near that degree.
If it was angled for installing the cards in a low profile case then why in the heck are the three PCI slots not slanted then? And were they thinking this is inernal only, or did they actually have the bracket holes in the back slanted to match the cards?
~The Creeping Network~
Reply 16 of 19, by snufkin
creepingnet wrote on 2022-01-13, 19:41:
Oh yes (and the 3rd PCI is angled over as well)...
    58.79 KiB
Reply 17 of 19, by BitWrangler
Lies!... that's not 45 degrees, it's more erect, but not sure it's 60 either, seems somewhere between the two like 55 or some crap.
Reply 18 of 19, by Big Pink
BitWrangler wrote on 2022-01-13, 19:58:
Damn OEMs and their non-standard angles.
It seems like the main slots are low profile (well, lower than full) and the angled shared slot is some compromise to acommodate older large sound cards.
Reply 19 of 19, by creepingnet
snufkin wrote on 2022-01-13, 19:53:
Hehe, whoah, that's wild. Vintage PC's, there's always some new crazy thing to learn every day.
