First post, by bbackhou
I am very new to this, but i have DosBox running on an old Dell D610 Laptop in Windows XP. I am trying to use it to run a Mikron Multistep Machining centre (manufacturing).
All the screens are working and i can communicate and receive data from the machine.
But when i try and send some programs to the machine, DosBox crashes with a "file date or file time is wrong" error screen. It works with some programs, but not others.
Is there a way to disable dosbox from checking file data stamps?
Reply 2 of 7, by bbackhou
Out of 100 parts we make on the machine, 93 work and send to the machine without error (using dos box). 7 fail with "file date or file time is wrong". When i check those files, they all have date stamps for the year 2056. Normal dos doesnt seem to care about this, but dosbox does.
Strangely, if i correct the data stamps to the current date (or prior), those 7 files still fail to send.
Reply 3 of 7, by jmarsh
When you say DOSBox "crashes", what exactly happens? Where does the error message appear?
Reply 4 of 7, by Stiletto
Please consider trying vDos, vDosPlus, other DOSBox forks, etc.
DOSBox is not intended to be used for anything other than games, and its developers and support team on VOGONS.org (the official support forum for DOSBox) will not support your use of it for a non-gaming application - but other forks of DOSBox might.
do the Fandango!" - Queen
Stiletto
Reply 5 of 7, by bbackhou
jmarsh wrote on 2022-01-19, 02:38:
File with the following errors:
File date or file time is wrong
TSR-Program Terminated
Reply 6 of 7, by jmarsh
Those messages aren't coming from DOSBox, they're coming from the software you're trying to run inside it. Sounds like it is too old to handle modern(ish) dates - basically a y2k issue.
Reply 7 of 7, by _Rob
Try setting the date back with the 'date' command in dosbox. After that generate the files and try again.
And as mentioned, you should use a dosbox fork that supports non-games, such as DOSBox-X.
