First post, by Muz
What is the best USB Support software for Windows 95?
Reply 1 of 18, by leileilol
Windows Me.
Reply 2 of 18, by jesolo
USB support in Windows 95 is limited and was only supported via the USB supplement that was provided with OSR 2.1 and later (you have to run it separately).
However, in most cases, you were still required to install manufacturer supplied drivers for certain USB devices (like flash drives or external hard drives). I believe that the Sandisk & Cruzer drivers are the most popular ones.
Windows 98 has better USB support and, via a third party USB Stack driver, also has much better support for USB devices like USB flash drives or external hard drives (I normally use the USB Stack driver that is supplied with the latest version of the Unofficial Windows 98SE Service Pack 3.x).
Reply 4 of 18, by Muz
It cannot detect the USB.
Reply 5 of 18, by derSammler
You need to install the two USB supplements first that came on the Windows 95 disc. And it must be OSR 2.x.
Reply 6 of 18, by Errius
Does a W95 mouse driver exist?
"AI Requires Proof That You Are Human"
Reply 7 of 18, by Muz
Where is the folder in the disc?
Reply 8 of 18, by derSammler
other\updates\usb
Mouse, keyboard, and other HID stuff works without the need for additional drivers.
Reply 9 of 18, by Muz
I installed it, and it cannot detect it at all.
Reply 10 of 18, by britain4
I had a ton of trouble the other day trying to get this to work. I gave up in the end and ended up using 98lite - you get the speed/appearance of 95 with the stability and driver support of 98.
The 98 NUSB mod does work with it but you need to extract the exe first, replace the explorer.exe with the 95 one and then run the setup from the extracted folder.
- 486DX2-66, SoundBlaster 16, Crystal VLB graphics
- P-MMX 200MHZ, PCChips M598LMR, Voodoo 1, AD1816
- PIII 933MHz, MSI MS6119, Voodoo3 3000, SB Live!
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500, SB Audigy
Reply 11 of 18, by Muz
I have tried the USB that came inside the disc, now it works.
Reply 12 of 18, by kolmio
Muz wrote on 2018-07-13, 19:00:
Do you have onboard USB controller or use an adapter card?
Windows 95 | Chaintech 486SPM M102.A | AMD-X5-133ADW or Am486DX4-100 | 48MB SIMM FPM | ATI Rage 3D II+DVD | CT4100 | 8GB CF
Windows 98 | Acorp 6BX86 | Pentium III 900, slotket | 512MB PC100 | Radeon 9250 | SoundForte SF16-FMI-03 | 64GB MicroSD
Reply 14 of 18, by Doornkaat
Guys, this thread was made by Muz and in 2018.
I don't think there is much point replying anymore.
Reply 15 of 18, by appiah4
Wait, what? Shit, I'm an idiot.
Reply 16 of 18, by kolmio
Doornkaat wrote on 2022-01-19, 07:34:
He visits the forum daily still
Reply 17 of 18, by Doornkaat
kolmio wrote on 2022-01-19, 08:51:
Yes. Read some of his contributions.
I may of course be wrong in my assessment so if your conclusions from his posts are different than mine feel free to keep trying to support him.
Reply 18 of 18, by Babasha
You can install Win95 OSR2.5 with Microsoft USBSUPP1 + USBSUPP2 packages and some third-party drivers to have USB-storage or optical drives support.
Unfortunately there NO USB-HID (keyboard and mice) support until Win98/NT.
Need help? Begin with photo and model of your hardware 😉
