First post, by Paratech
I should be getting it maybe by Monday, I just 'won' it on EBay.
I was curious as to how much trouble it'll be to get running...
I was always fond of that game, I don't even think the PC version has copy protection,,,the C64 version made you use the manual, which I lost in a basement flood, although I'm sure I could find it on the net if I took some time...
I figured if I could buy the PC version for $6 *which I won with* it would be worth it, and yes that included shipping...
Any suggestions on getting it running are appreciated...
Reply 1 of 13, by Kippesoep
It works perfectly in DOSBox, without any special configuration.
The PC version also makes you check the manual.
My site: Ramblings on mostly tech stuff.
Reply 3 of 13, by Kippesoep
IIRC it didn't on a real PC either.
Reply 4 of 13, by eL_PuSHeR
As far as I can tell Battle Chess had digitised PC-Speaker sounds.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 13, by Kippesoep
The VGA version does, I don't recall ever having sound on the EGA version on my 12MHz 286 with EGA. That was nearly 20 years ago, though.
Reply 6 of 13, by eL_PuSHeR
My 1988 EGA version play digitised sounds just fine under DOSBox 0.70 - I have never seen a VGA version. Game uses 16 EGA colours. I don't know about the video mode used, though.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 7 of 13, by Kippesoep
Looksee.
Reply 8 of 13, by eL_PuSHeR
Definitely, I have the EGA version. Thanks for the comparative screenshots.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 9 of 13, by Kippesoep
There is no intro music or movement sounds in the EGA version. There are battle sounds. The VGA version has all three.
Reply 10 of 13, by eL_PuSHeR
Yes, I was referring to battle sounds. Thank you for clarifying things up.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 11 of 13, by leileilol
I've got the later 1992 SVGA version and apart from some common installation niggles, it works just fine 😀
Debian's fucked
Reply 12 of 13, by Paratech
It looks, according to the auction, that I am getting the 256 color version!
I'm really looking forward to it!
Thanks for the heads up...
Reply 13 of 13, by Paratech
I got it today, and after fudging with the 60 second guide, I got it running.
It was an OEM version and didn't use documentation protection.
I just had to install the CD and mount the CD as a CDROM/
