PowerVR Fun Thread
Reply 840 of 1124, by leileilol
Yep, the rocket launcher and players are red. 😁 shows that the driver did attempt to load the higher textures but is picking the other mipmap levels for rendering.
The blue fire hole floor is interesting too as that's a RGBA4444, loaded before the weapons and still gets pushed to the back
My only other ideas are to see if r_finish and r_primitives 1/2/3 do anything.
Reply 841 of 1124, by Hanamichi
Chadti99 wrote on 2022-01-20, 12:58:
So should we start a new Neon 250 thread or keep the fun rolling here? Just calling out there are several new owners of this card, probly with questions like me. Has anyone been able to use “high texture detail” in Quake 3 without some textures obviously not loading correctly? Check the gun in the pic.
Let me know the Q3 settings that gives you this, I can test on an original Neon this weekend.
The reviews don't mention any issues like that and I think they went up to 1600x1200 on 'high'
I find the drivers hard to swap, needed to clean the registry each time or a fresh install which was pita.
Reply 842 of 1124, by Chadti99
The problem appears for me when I slide the texture detail setting all the way the right. If I pulled it back one notch, no problem.
Reply 843 of 1124, by leileilol
32-bit textures and picmip 0? You're definitely pushing a 32mb card. It doesn't look like it's using 32-bit anyway (see the bandedness of that texture quality slider graphic, it's still 16-bit there)
When loaded, type /imagelist in the console to get an (approximate) amount of video memory usage for textures.
Reply 844 of 1124, by Putas
IIRC the slider gives picmip 1 at best.
Reply 845 of 1124, by Chadti99
leileilol wrote on 2022-01-21, 15:33:
Even on “16-bit” same issue.
Running the command I get info back about 6734528 total texels and 324 total images.
Reply 846 of 1124, by Chadti99
If it helps, I’m using version 1.2.0.9 of the MiniGL, assuming it’s a MiniGL.
Reply 847 of 1124, by Chadti99
Just tested with 1.2.10, same results.
Reply 848 of 1124, by Hanamichi
So I've got a fresh install of W98SE OEM.
Plonked on Q3 Gold from GOG.
Installed the earliest drivers and later ones from vogon drivers. Tried the early opengl32.pvr (rename to .dll and plonk in the dir) as well as the MiniGL config program and set to QIII folder.
I don't see any corruption like your photos regardless of settings..
but I do get a hardlock after a few seconds... no matter what..
Runs okay in Unreal so it's not the card.
CPU is a PIII Xeon running at 500MHz
I'll find an old Q3 executable and try again. Are you using the original CD install?
For your issue did you try AGP apeture settings?
Reply 849 of 1124, by Hanamichi
Chadti99 wrote on 2022-01-21, 12:49:
Alright progress..
It's sensitive to AGP aperture size..
On my 440GX platform
128mb aperture -> fast hard lock
64mb aperture -> fast hard lock
32mb aperture -> plays for 15 secs then hard lock but no missing textures
16mb aperture -> plays without locking up but missing textures spotted with the highest details
There is an option in the driver "Force all Texture to AGP Memory" for MiniGL this made things worse predictably.
This was with 3.1.1.36 driver and original opengl.pvr from the CD folder (not techlands)
There is a late patched neon250 minigl and techlands minigl I have not tried yet.
Apart from that issue it plays Q3 impressively well for 1024x768.. bit of early Kyro magic.
Reply 850 of 1124, by Chadti99
Are you referring to AGP aperture setting in the bios setup? I have the PCI variant of the Neon 250, would it have any effect?
Can you share any Quake 3 timedemo scores ?
Reply 851 of 1124, by Hanamichi
Q3 Gold from GOG
Xeon 550Mhz @ 666MHz 😁
128mb ram <- I think my issues are memory related actually, tried a different stick or two and Q3 crashed instantly no matter what setting. Need to find at least 256mb that works and run memtest
440GX @ 120MHz FSB
GL Driver: Default
GL Ext: on
Video Mode: 800x600
Color Depth: 32
Fullscreen: on
Lighting: Lightmap
Geometric: High
Texture Detail: 1 down from max
Texture Quality: 32 bit
Texture Filter: Bilinear
timedemo 1
demo four
56.6 fps
Reply 852 of 1124, by Hanamichi
Ah yes sorry you have a PCI version...hmmm
Chadti99 wrote on 2022-01-23, 21:06:
Yes
I don't think so but no harm in trying
AGP Textures was a selling point if implemented correctly
My knowledge on that isn't great but I think that would be why, once you hit 32mb a PCI card chokes and starts swapping.
A good AGP implementation can use a portion of system memory to buffer although it's of an order slower.
See my other posts and here for reference: https://www.tomshardware.com/uk/reviews/video … iew,131-10.html
Reply 853 of 1124, by Hanamichi
Also got max textures settings working now with random memory stick swaps/ bios tweaks .
Basically if I set less then <32MB AGP Apeture size I see your artefacts/lack of textures.
Once at 32MB it runs fine, I guess it's just creeping up to over the 48MB+ memory used for max detail textures.
Anyway it's just one game and high setting.
GL Driver: Default
GL Ext: on
Video Mode: 1024x768
Color Depth: 32
Fullscreen: on
Lighting: Lightmap
Geometric: High
Texture Detail: max
timedemo 1
demo four
31.4 fps
Reply 854 of 1124, by libv
Is there any source code out there for powervr version of Q3?
Reply 855 of 1124, by leileilol
There is no PowerVR version of Q3. What's going on in this thread is stock Q3 being played with separately available supplemental MiniGL drivers for the Neon250. There's no source code publicly available for any of the established PowerVR MiniGL drivers (extreme, neon250, techland)
Reply 856 of 1124, by libv
leileilol wrote on 2022-01-26, 19:48:
Hrm. I see. And while I do see an sgl.dll in the neon-250 drivers and it supposedly is compatible with that known interface, is there a header for SGL2 available that you know of?
Reply 857 of 1124, by Chadti99
Is there a way to adjust gamma in GLQuake on say a Matrox M3D? Things are just a bit too dark on one specific setup.
Reply 858 of 1124, by leileilol
I'd advise pumping up the host video card's gamma instead (if color adjustment control is available). Some swear by some old 'idgamma' tool but that's way too lossy in my opinion.
for reference, 3dfx cards through 3dfx's MiniGL use gamma 1.7
If this were a Kyro card, you could set the OpenGL hardware gamma correction at the per-app driver level 😀
