First post, by Pierre32
I've got a Voodoo that was received DOA. Passthrough works fine, but launching a Glide game will either result in a blank screen (eg. Descent 2) or some garbled nothing (eg. NASCAR 2). For reference this is a pure DOS system, which happily runs all titles with a different Voodoo.
It matches the generic "3920465A1 600-0012-04" here, which is a pretty close clone of the ColorMAX VP-503: http://www.vgamuseum.info/index.php/cpu/item/1-3dfx-voodoo-1
In this shot you can see things look a bit ordinary around C31, C32, C103, C104, C106.
And even more so at C163 & C164. C169 & C190 looking a bit dodgy too:
Note the the card had a thorough clean after these photos to remove the gunk, to no effect.
Any thoughts on how to progress with this? Is there any information out there that identifies the components on this card?
Reply 1 of 5, by ciornyi
Hey mate,
How did you tried to clean ?
Its hard to say what kind of liquid or what cause this . Anyway as C164,163,169 &190 its capacitors and theyre same as C211,210,169 &170 or C54,56, 94&95 . As for C31, C32, C103, C104, C106 its harder cause there is no reapeting elements
DOS: 166mmx/16mb/Y719/S3virge
DOS/95: PII333/128mb/AWE64/TNT2M64
Win98: P3_900/256mb/SB live/3dfx V3
Win Me: Athlon 1700+/512mb/Audigy2/Geforce 3Ti200
Win XP: E8600/4096mb/SB X-fi/HD6850
Reply 2 of 5, by Pierre32
Interesting info, cheers. Cleaning process today was vinegar + stiff antistatic brush on the worst areas (including those bubbly parts of the traces you can see in the last pic), then water rinse, then a general clean with contact cleaner.
Reply 3 of 5, by TrashPanda
Looks like its been sitting out in the open where water can get to it, them bubbled traces look like corrosion bubbles.
Reply 4 of 5, by whaka
you can also check continuity of corroded vias, some of them are probably cut.
very strange corrosive attack...
Reply 5 of 5, by TrashPanda
whaka wrote on 2022-01-23, 14:44:
Ya know .. it kinda looks like someone spilled a drink into the case, it reminds me of a friend who used to sit their cup of coke on top of their tower PC which had vents in the top ... well he used to do this till one day he up ended the drink into the vents. Totaled the PC but the corrosion spots on the back of this card remind me of soda dripping onto it while it was running, some of them do look like some kind of sticky residue.
Unless its Flux residue from someone trying to repair it previously.
