First post, by keenerb
It's running windows 3.11. MSBACKUP and 200 floppies seems to be pretty much my only real option?
I can probably get a parallel port NIC up and running tho, now that I think about it...
Reply 1 of 6, by Disruptor
Serial Port & INTERLNK.EXE or Laplink?
Reply 2 of 6, by TrashPanda
keenerb wrote on 2022-01-24, 03:55:
You can burn CDs on a 486, so you could even back up to a zip file and burn it to a CD if the machine has one, kinda slow but Laplink or NIC is going to be slow too.
Reply 4 of 6, by lolo799
You could use a parallel port Compact Flash adapter along with an old version of Ghost, dolly or any Dos based disk imaging utility.
Or g4u with an MCA network card, depending on how much memory your machine has.
How big is your hdd?
Reply 5 of 6, by keenerb
I do have a parallel port CF adapter. That's a good idea. Hard drive is only 200mb.
I think for a DOS/WINDOWS 3.11 machine something as simple as XCOPY can be used to take a backup?
