First post, by Plazzmha
DosBox Can't Swap memory pages between Games and a Memory Resident Program ?
Error has accourd when i try to use the Game Wizard/Infinity=={GW/I} while i play game X-Com 2 TFTD.
These following step that i do .. until error rised.
1. Run DosBox (v0.7)
2. Run the MR Program {GW/I}
3. Run the Game
4. Swap the memory with the Program .... then bang error!
If anyone want to try it, PM me your mail and i would sent the program and the game.
Note : Game Wizard/infinity is a memory hacking tools similiar with Game Hack 2.0.
My Computer spec :: Processor=Via C3 Samuel,mem=128,os=XP.
Please help to identify this problem, why DosBox had this error.
Reply 1 of 2, by VisitntX
You should use GAME WIZARD 32 to make cheats in dosbox, that program is DOS based and works without problems in dosbox. At least I make dozen of cheats and all of them worked perfect.
Reply 2 of 2, by franpa
i got a hack program for crystal caves 1 and it works fine following the same instructions.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
