Reply 20800 of 30138, by Jed118
BitWrangler wrote on 2022-02-03, 02:42:
The early 21st century crop of 4 head VCRs with instant auto tracking and comb filters etc make tape look a lot better than they did in the 80s or 90s. Only Betamax looked that good back in the day!
I have a mid 90s Sony 4 head - wonderful piece of tech. My wife won't let me set it up with the home entertainment system in the living room, but in all honesty I only have 5-6 tapes for it anyhow. I mainly use it to capture footage off of.
LHN91 wrote on 2022-02-03, 02:49:
Edit: actually Christmas '91, the commercials in the Bette Midler movie were for Canadian Tire Christmas sales and the '92 GM/Chevy/Geo lineup.
I'd be interested in seeing that CTC commercial - I think at that time, I ordered stuff from it to a letter for"santa" (H0H 0H0)
What's for sale? my eBay!
Reply 20801 of 30138, by TheAbandonwareGuy
OK so the 3DLabs Permedia 2's OpenGL ICD is COMPLETELY broken in Half Life. Runs horrribly with only basic colors loading, no detail textures to speak of. Direct3D mode works fine. FireGL indeed, as in dumpster fire.
Can anyone recommend a good VGA capture device? I would like to document this sort of stuff.
RetroEra: Retro Gaming Podcast and Community: https://discord.gg/kezaTvzH3Q
Cyb3rst0rm's Retro Hardware Warzone: https://discord.gg/naTwhZVMay
Reply 20802 of 30138, by Kahenraz
One trick is to keep an eye out for a VCR with the "S-VHS" logo on it. I found that these always made any regular tape look better due to whatever wizardry was happening inside.
Reply 20803 of 30138, by X86
The attachment tx97x.jpg is no longer available
New build in the works. going to be running windows 95.
pentium 233mmx
asus tx97-x
64mb ram
diamond s3 virge 3d 2000
sound blaster 16
in search of a voodoo 1 that doesn't cost an arm and a leg
Reply 20804 of 30138, by BitWrangler
Jed118 wrote on 2022-02-03, 03:10:
Yah that'd probably be one of the higher end ones that first had it before it filtered down to the under $100 in Walmart models.
Reply 20805 of 30138, by Joseph_Joestar
I've been testing 5.1 surround sound capabilities of some older games. Was pleasantly surprised that the original Deus Ex which was released in the year 2000 supports this. I then tested Unreal Tournament '99 and, sure enough, surround sound works there as well.
Didn't realize that 5.1 support in games already existed this early. Cool stuff.
Reply 20806 of 30138, by appiah4
TheAbandonwareGuy wrote on 2022-02-02, 23:09:
Is there even a point to DDR memory on the PCI bus? Like a GeForce2MX with 32MB of SDR more than saturates the bus, and can barely run Morrowind at 640x480 lowest settings. I need to find a 64MB DDR AGP card to compare against, but it seems like 64MB + DDR + AGP is a rare combo. Most AGP cards only have 32MB of memory OR are SDR.
You do realize that being DDR also means double the transfer rate between GPU and DRAM, not just over the bus right?
Reply 20807 of 30138, by Jed118
BitWrangler wrote on 2022-02-03, 04:36:
I picked it up when my Uni's A/V were throwing out old equipment, like 15 years ago, maybe even more than that. It still has the orange band on it, indicating that it came from the orange closet 😉 Believe it or not, we still have two of them in semi-active use 😉
Reply 20808 of 30138, by appiah4
X86 wrote on 2022-02-03, 04:07:
You, and the whole "remember when.." generation 😒
Reply 20809 of 30138, by GigAHerZ
LHN91 wrote on 2022-02-02, 23:31:
Not retro computing, but retro... doing some VHS captures for family, and one of the tapes had a downright flashy, embossed, golden label. Honestly I've never seen anything like this on a VHS tape.
It is retro computing, if you consider this:
https://www.youtube.com/watch?v=TUS0Zv2APjU
Reply 20810 of 30138, by NyLan
Today I saved a Floppy Drive.
From outside it was looking very good. No "glue" marks, no scratches, almost looking like it's been never used.
But inside....
The attachment 2022-02-03 09.48.04.jpg is no longer available
The attachment 2022-02-03 09.48.25.jpg is no longer available
After cleanup, and even some greases on the stepper motor spindle
The attachment 2022-02-03 10.35.55.jpg is no longer available
The attachment 2022-02-03 10.36.29.jpg is no longer available
The attachment 2022-02-03 10.42.31.jpg is no longer available
Now working like a charm !
Mission accomplished
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 20811 of 30138, by ODwilly
My RGB mechanical wal-mart keyboard suffered 3 keys that no longer work while I tried to login last night. Dell Quiet Key to the rescue!
Reply 20812 of 30138, by BitWrangler
NyLan wrote on 2022-02-03, 10:06:
Today I saved a Floppy Drive. […]
But inside....
They get like that when there's the PSU and maybe one other fan pushing air out, but no intake fans or free breathing large grilles... air gets "filtered" through the poor floppy drive.
Reply 20813 of 30138, by NyLan
BitWrangler wrote on 2022-02-03, 13:50:
But inside....
Yep, most likely. On old computer most of the time you only had the PSU Fan. I'll post another picture of the drive later today. The bottom is not made as other with a thin sheet metal. It's a thick aluminium piece.
It looks so nice 😊 😎
Personal GitHub
Reply 20814 of 30138, by TrashPanda
Bought a SCSI Ultra 320 HBA card with 4 head cable and terminator, gonna see if these Ultra 320 drives I have are still kicking, if so then perhaps one of the P3 machines I have will inherit 4 15k 80gb SCSI drives, tho I do wonder how hot these suckers get under normal use and if I should case mod some cooling fans into the front to cool them a bit.
Thinking about it .. I remember these things sounding like a jet engine so I should invest in some sound deadening material too.
Reply 20815 of 30138, by PD2JK
And the P3238 is alive and kicking booting. Nothing beats the sound of an initializing ST-157A!
After that it booted DOS 4.01 and Windows 3.0... Happy Days.
The correct drive type was number 10. After running setup.com (to access the CMOS setup), it magically changed to drive type 25. Ha! Oh... hmm...
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 20816 of 30138, by pinesal
Jed118 wrote on 2022-02-02, 19:01:
pinesal wrote on 2022-02-02, 18:36:
I am going to Twitch stream myself installing Windows 98 and a drivers and other software tonight.
People watch this? I'm only asking because I do similar things on YouTube - send me a link to your stream pls.
I had a few of people pop in but it wasn't a hugely successful stream. But I'd do it again.
My statistics were
Average Viewers: 2.7
Number of Unique Viewers: 10
LINK here https://twitch.tv/90snick_pinesal
Hang out in the 90s with me on Twitch: The 90s Retro Gaming https://twitch.tv/90snick_pinesal
Retro Battlestation:
FIC VA-503+
AMD K6-2+ @ 600mhz
ATI Rage Fury 16MB
128mb PC100 RAM
137GB SSD
Windows 98
Reply 20817 of 30138, by liqmat
pinesal wrote on 2022-02-03, 16:18:
I had a few of people pop in but it wasn't a hugely successful stream. But I'd do it again. […]
My statistics were
Building an audience can be challenging. If you are going in for that and want to monetize make sure to stay consistent. I have read two to three times a week. In other words... work. I do about one video every three to four months. I'm taking the world by storm. 🤣 Seriously, though, if you love to do it, keep at it.
Edit: Love that room you work out of. It's a playground!
Reply 20818 of 30138, by NyLan
NyLan wrote on 2022-02-03, 14:02:
But inside....
See the thick aluminium piece. First time I see a 1.44MB Floppy drive manufactured like this.
The attachment 2022-02-03 17.28.13.jpg is no longer available
The attachment 2022-02-03 17.28.30.jpg is no longer available
Personal GitHub
Reply 20819 of 30138, by Joseph_Joestar
Currently re-watching the Lord of the Rings Extended Version DVDs on my AthlonXP rig running Win98SE.
For this purpose, I've connected the SBLive 5.1 to my Logitech X-530 speakers. I was originally using VxD drivers, but for some reason, the center channel always remained silent, regardless of what settings I tried. After switching to WDM drivers, I'm getting proper 5.1 surround sound, and it's working perfectly.
For playback, I'm using PowerDVD, just like in the good old days.
