Reply 3460 of 4604, by Kahenraz
- l33t
Tetrium wrote on 2022-02-03, 13:40:It does make replacing the fan more difficult though, I've experimented with snipping out the old fan and adding a small CPU HSF fan on top of it using that strong black tape which you can tape basically anything down with 😜
It really depends on the kind of cooler you have. My favorite coolers for the Pentium 2 have metal hooks on a hinge that you can flip to secure or release. They are strong, durable, and the convenient hinge makes attaching them between processors for testing a breeze.
The worst heatsinks by far are those stupid friction fit plastic posts that fit into the Pentium 3 cartridges which are almost impossible to remove without breaking. In one instance I ended up damaging the SMD capacitors while trying to lever the heatsink off when the plastic posts wouldn't come out. In the end I was able to cut the posts with a pair of edge cutters and later repaired the damage to the processor itself.
This problem with cutting these plastic posts is that it blocks the holes which are necessary to mount a heatsink to the processor. To remove bits of posts which remain, I remove the PCB from the housing and push them out with a screwdriver. Sometimes this will cause the plastic housing to crack on the inside due to the impact of the tip on the frame, but this is often minor damage, is only visible from the inside, and is worth the trouble as the processor is otherwise useless without the mounting holes being clear of debris.
