First post, by Jason_rg
Hi all
Looking to some interesting topics refering Miniscribe drives, I havent found any info about Miniscribe XT controllers.
May be some one could help for findeing one XT Contoller board Bios used with M8225XT hard disk, due to the bios is broken. Not possible to read.
May be there are some "compatible" Bios available. Any Help will be apreciated.
The Hard disk It looks broken due to no head moving, but spinning.
Some board picture attached:
The attachment 20220206_123303.jpg is no longer available
The attachment 20220206_123128.jpg is no longer available
More helpfull info founded in this web in the past (like amstrad 8256 floppy adapter), expect to find more info about this controller.
Thanks to all.
Regards
Reply 2 of 6, by rmay635703
Odd one wonders if an actual XT 8-Bit only controller could just use the generic “16bit XTIDE” bios one uses in the home built 16 bit XTIDE controller?
XT compatible drives are getting hard to find, might need to bite the bullet and get a 16 bit compatible card.
The only system I encountered XT drives were in Tandy’s which had the ideotic smart drive software requirements
Reply 3 of 6, by rasz_pl
Olivetti Prodest PC1-HD, Commodore, there were a few systems with 8bit IDE
https://www.vcfed.org/forum/forum/genres/pcs- … isk-replacement
Reply 4 of 6, by rmay635703
rasz_pl wrote on 2022-02-07, 17:45:
8 bit ide released after the 16 bit Winchester version and never made much sense
My other thought was the ide standard both controller and drive should have had autosensing for 8 bit / 16bit and been interchangeable.
Some 16bit drives will accept 8 bit transfers which means only the pinout was a problem which is an extremely stupid limitation to having a universal standard between both controllers
Reply 6 of 6, by Jason_rg
Hi all
Sorry to "revive" this old topic.
Finally I was able to try new card controller, same model.
I have dumped the card Rom and It will be ready for everybody in case needed:
The attachment miniscribecontroller.rar is no longer available
Regards
