First post, by attorianzo
...black screen, but I hear background game sounds..
Any suggestion?..
Reply 1 of 12, by eL_PuSHeR
Here is the Playable demo (< 7MB) for anyone interested in testing.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 12, by MiniMax
Rank Moderator
Moderator
I tested the demo 3 weeks ago - works fine. I had to set CPU cycles to 6000 to avoid stuttering sound, but that was it.
@   echo off
mkdir C-drive
mkdir capture
set DOSBOX_CPU_core=dynamic
set DOSBOX_CPU_cycles=40000
rem Unzip the demo into directory "Unpacked".
"%ProgramFiles%\7-Zip\7z" x -y -oUnpacked indycar2.zip
rem Install in C:\ICR2.
"%ProgramFiles%\DOSBox-0.70\DOSBox" -c "mount C C-drive" -c "mount U Unpacked" -c "C:" -c "U:\ICR2demo" -c "exit"
Configure sound for SoundBlaster-16.
set DOSBOX_SBlaster_SBtype=sb16
set DOSBOX_GUS_GUS=false
rem "%ProgramFiles%\DOSBox-0.70\DOSBox" -c "mount C C-drive" -c "C:\ICR2\setup" -c "exit"
rem Run the demo. Has to lower the CPU cycles or sound will stutter.
set DOSBOX_CPU_cycles=6000
set DOSBOX_RENDER_SCALER=normal3x
"%ProgramFiles%\DOSBox-0.70\DOSBox" -c "mount C C-drive" -c "C:\ICR2\IndyCar" -c "exit"
_________________
Reply 3 of 12, by eL_PuSHeR
Demo works fine for me also and I didn't have to adjust anything.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 12, by VisitntX
I have that problem fixed from the setup, uninstall vesa driver, the game will works but in VGA only. In dosbox 0.63 works fine the SVGA but is really low.
Reply 5 of 12, by Neville
I've played the game in both VGA and SVGA modes with v0.70. It works great, provided you do as advised and uninstall the UNIVBE driver from the setup program.
Reply 6 of 12, by attorianzo
Great! I've only uninstalled univbe from setup.exe and now "indycar -h" runs perfectly with the best graphic detail 😀
Unfortunately i've not an analogic joystic but I think it is the best racing simulation of DOS 😀
thanx all 😀
Reply 7 of 12, by Neville
That's only because you haven't played "Rally Championship" and "Nascar Racing 2" enough. 😁
Reply 8 of 12, by VisitntX
So all I have to do is add the command -h. I will try it later. Thanks for that.
Reply 9 of 12, by Paratech
I snagged a copy *used but legal* at a Goodwill, I haven't gotten it fully up and running yet, but I did get to try it out a little bit. It was fun.
Need for Speed is also fun.
Reply 10 of 12, by VisitntX
Yep the game works perfect with -h. Thanks for that.
Reply 11 of 12, by Jack Deth
When I try to uninstall the UniVBE driver. I get
"Unable to Uninstall UniVBE driver"
Well after looking through the files, I found a file called UniVBE.drv, I deleted it and the game worked.
Reply 12 of 12, by Neville
Then you probably didn't have it installed in the first place. Does the game still show a black screen?
