First post, by idan182
Hi all
I currently have 512MB SDRAM in the system.
Computer recognize it as 256MB.
I want to switch to either 32MB or 64MB.
The computer I'm using is mainly for DOS+WIN98
I play old DOS games which doesn't work and require "ems memory"
I get an error message on some games that no EMS memory is in the system.
Does EMS needs set up? or that would be automatically if I use EDO RAM?
Reply 1 of 9, by alvaro84
idan182 wrote on 2022-02-17, 14:41:
The presence of EMS doesn't depend on the used memory type at all. It indeed needs a driver, either EMM386 or the like under DOS or given by Win98 to its DOS tasks.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 2 of 9, by dormcat
EMS has nothing to do with either EDO RAM or SDRAM; you have to use an expanded memory manager (EMM386, QEMM, etc.) in config.sys in order to emulate expanded memory (EMS) using extended memory (XMS). Many 386-era DOS games require EMS to run; later games use DOS/4GW to access protected mode, rendering most memory managers obsolete.
Reply 3 of 9, by dionb
Also, 512MB or 256MB is massive overkill for DOS memory and may itself cause errors (insufficient memory, because counters roll over on this sort of quantity). It's very likely you have installed more RAM than the motherboard chipset can cache, causing degraded performance.
Can you identify the motherboard? Or at least the chipset? That would tell us what the optimal amount of RAM would be.
Tbh, I find 16MB generally works best for DOS.
Reply 5 of 9, by AirIntake
maxtherabbit wrote on 2022-02-18, 04:04:
I have never encountered a situation where any problems whatsoever were incurred from having >=64MB of RAM
Wing Commander Privateer will have corrupted digital sound effects unless you limit your RAM to 16MB. Can't think of any others off the top of my head.
Casio BE-300 Advancement Society alumni
Reply 6 of 9, by Joseph_Joestar
Aladdin won't start on a machine with more than 32 MB.
Reply 8 of 9, by NyLan
Joseph_Joestar wrote on 2022-02-18, 20:34:
Using eatxms for this issue works fine
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
