Reply 20940 of 30137, by Deunan
Installed Debian 1.0 (with 2.0.0 kernel) on 386DX-40. TCP/IP works on 3Com 509B. This machine has 8MiB and while README says only 4MiB is required, it would be like having only 512KiB in DOS. I will try to boot with just 4 once, but I don't want to wear out the CF card with constant swapping.
Also, boy, I'm not exactly a Linux person but I do manage, and I have been using it for quite some time, but I had to brush up on some networking commands and locations of config files. I wonder if there is a version of Midnight Commander ancient enough to compile on glibc5 system?
Also, if anyone know why I can't mount NFS shares please let me know. Is Debian 1.0 still using NFS2? Or is it somehow ext2 vs ext4 issue? Well, next thing to try is to set up local FTP server with the distro packages instead...
