First post, by vkcpolice
What would give better performance i have both a slot celron 366mhz and a Pentium 400mhz
i didnt notice much difference when gaming while playing the original cod
the Pentium 2 cpu had a huge heat sink but no fan i pulled it out of a old dell computer.
the cpu got very hot so i shutdown and put the celron back in.
ps i was running a nvidia 550fx pci and 192mb ram
Reply 1 of 11, by AlexZ
Celeron 366 clocked at 550Mhz (5.5 x 100). Buy a few of them and one of them will run at 550 for sure.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, NVIDIA GeForce FX 5600 128MB, Voodoo 2 12MB, 80GB HDD, Yamaha SM718 ISA, 19" AOC 9GlrA
Athlon 64 3400+, MSI K8T Neo V, 1GB RAM, NVIDIA GeForce 7600GT 512MB, 250GB HDD, Sound Blaster Audigy 2 ZS
Reply 2 of 11, by bofh.fromhell
vkcpolice wrote on 2022-02-26, 15:05:
What would give better performance i have both a slot celron 366mhz and a Pentium 400mhz i didnt notice much difference when ga […]
Pentium 2 at 400MHz will outperform a Celeron at 366MHz in everything.
~10% higher frequency does its thing, but more importantly the P2 runs at 100MHz FSB compared to the Celeron's 66MHz.
Given the same frequency and FSB its much closer.
A Celeron 300MHz easily becomes a C450MHz and can them be compared directly to the P2-450MHz.
As far as i can remember games often favored the Celeron and productivity stuff liked the P2.
And as mentioned above, there is a chance your C366 can run at 550MHz, making it a lot faster then your P2-400 =)
If your motherboard allows changing FSB regardless of what the CPU tells it to use then just try 100MHz and hope.
All hope is not lost for OEM boards tho, the famed "B21" pin trick should work regardless.
Reply 3 of 11, by Sphere478
They are the same chip with some configuration and feature differences
Celeron fsb is 33 mhz slower
The celeron core is 33mhz slower
The celeron has less cache
Others are correct, there shouldn’t be anything that the celeron is faster at.
Interesting side note. I recently found a article where someone managed to put two slot celerons in dual processor configuration
Sphere's PCB projects.
Reply 5 of 11, by Sphere478
rasz_pl wrote on 2022-02-27, 00:04:
Sphere478 wrote on 2022-02-26, 18:32:
Didnt that require quite elaborate mod involving drilling out pins?
Yes
Reply 6 of 11, by gdjacobs
They are the same chip with some configuration and feature differences […]
Covington core Celerons had no L2 cache and are considered to be quite poor relative to Klamath and Deschutes Pentium II CPUs with 512kb L2 cache at half speed. Mendocino core Celerons (Celeron As) had 128kb of L2 cache at full speed, so they had a performance advantage with tight looped code.
Reply 7 of 11, by Tetrium
You could shoehorn a fan to or close to the huge passive heatsink and then retest it to see if the overheating still occures.
The 2 CPUs should be close in performance, but I'd pick the Pentium 2 400MHz because it's still a little bit faster and probably easier to cool more quietly as it has that huge heatsink attached to it.
It probably doesn't even need a whole lot of airflow to keep cool btw but it will still need some.
The Dell it came out of probably had some kind of air duct to help with cooling it via the PSU fan.
My retro rigs (old topic)
Report spammers here!
Reply 8 of 11, by Anonymous Coward
One advantage of the Celeron 366 is that it has less parts to fail. If we're talking about the S370 version, they have an integrated heat spreader making them very hard to damage. I owned both a Celeron 366 and a PII-400 in the late 90s. I ran the Celeron 366 overclocked to 412MHz on a 75MHz bus. I couldn't get mine to do 550 as envisioned. I remember at 412 its performance was very close to the PII-400. The Celeron setup was completely reliable, and I never had the slightest issue with it. The PII-400 on the other hand just suddenly died one day. I think I bought it in 1998, and it died in 1999. This was surprising to me, especially since it had never been overclocked! It was the SECC2 version, made in Ireland.
Reply 9 of 11, by rmay635703
Since I was always moving systems I had tons of trouble with “slot” systems didn’t matter if it was Slot A or 1 , my slot a burned traces or bad solder joints to
PCI 1, sdram 1, temperature sensor, fan headers
I kept it running a decade by constantly reseating things and by hard wiring components
The socketed systems I had were mostly rock solid, though systems made in the last 15 years seem to have garbage proprietary power supplies
Reply 10 of 11, by BitWrangler
Slot 1 always seems to have "The Nintendo problem".... you gotta pull the cartridge out and blow on it when it don't work.
Reply 11 of 11, by vkcpolice
Tetrium wrote on 2022-02-28, 13:29:
correct the dell had a fan on the back of the case that was facing the cpu
it did get very hot so ive got to find a fan to fit onto it.
i dont have anything on hand atm and the heatsink is huge.
I will post pics of both the cpus next time i have the case open
