Reply 140 of 346, by mockingbird
dj_pirtu wrote on 2022-02-26, 08:30:But, if you want that ISA slot... And I do because of Gravis Ultrasound. But all the later VIA-chipsets are really good, 100% SB PRO support in DOS with ESS SOLO-1.
Hey, since you had luck with PCISET before, maybe you can figure out why this won't work with the SOLO-1:
pciset 1969 125D 52 00000001 00000010
This is supposed to toggle SB-LINK to on (change register 52), but it just returns a "0" result... If I could get that to work I would replace my YMF724 with it on my Northwood system... The SB-LINK on the YMF724 works just fine, but I would much rather have the SOLO because of the internal wavetable header and full ADPCM support.
I'm off now to test SETMUL with your trick, will report back shortly.
