Reply 20 of 32, by feipoa
There was some thread where someone mentioned to me that they have what looked identical to the Mac version of the 128 GL, but worked fine in his PC.
As for the NIB card from that interloper seller, unless you are after a Rage 128 Pro in PRO format, I wouldn't buy it. His listing said it was for 128 GL, I bought it (some time ago), and the card was a 128 PRO. I mentioned this to him, but he didn't respond to me. Here's some photos of the contents.
Notice how the card says 128P? I believe the "P" is for "Pro". When I went to setup the drivers, it said it was Rage 128 Pro.
180.2 KiB
114.35 KiB
372.75 KiB
303.15 KiB
Reply 21 of 32, by aspiringnobody
feipoa wrote on 2019-07-16, 08:29:
There was some thread where someone mentioned to me that they have what looked identical to the Mac version of the 128 GL, but w […]
If you still have this card, would you be able to dump the bios for it? It might be what I need to get one of those Diablotek Rage 128 Pros booting on my vintage PCs. The bios must have an SSE/SSE2 instruction in it because the card never initializes on retro kit. Works fine in newer computers, although I don't know why you'd want to use it in them.
The PCB layout of this card is identical to the Diablotek "reproduction" except this has a copyright of 2001 and the Diablotek has a copyright of 2003. Maybe this card has an older bios as well?
Thanks!
Reply 22 of 32, by feipoa
I can try; that box is buried behind numerous PC towers and motherboard bins. I may also have the Chinese generic 128PRO card in the box. Do you want that generic VGABIOS as well? Since the BIOSes are soldered, I'll have to use NSSI. I don't particularly want to desolder the EEPROMs to read their contents.
Reply 23 of 32, by astonsmith
Hi everyone,
I have a Connect 3D version of the Rage 128 Pro (C3D 6000, 32MB). Interestingly, it's marked on the board as an "ATI-128 PRO/ULTRA".
I've no idea if this helps anyone, but in case it does, I've used NSSI to dump its VBIOS (as it's soldiered onto the board).
2002/04/10 09:50
CONNECT 3D RAGE128 PRO BIOS V1.02 -PAL
(C) 1988-99, ATI Technologies Inc. BK3.0.2 VR001.001.003.003.000.026
Hopefully this works, because apparently "the extension VBI is not allowed".
    vbios.zip
    28.63 KiB
    79 downloads
Reply 24 of 32, by feipoa
Attached are two Rage128 Pro BIOSes. One is for the retail boxed ATI XPERT128 rage128 pro, the other is for a Chinese generic repica rage128 pro. BIOS was written by NSSI.
I'm not sure why the Chinese generic BIOS is 45K while the ATI one is 32K. Usually BIOSes come in standard sizes, like 32KB, 64KB, 128KB, etc.
Both BIOSes are from PCI cards. The ATI has 16 MB memory, while the Chinese has 32 MB.
Reply 25 of 32, by aspiringnobody
astonsmith wrote on 2022-02-26, 12:31:
Hi everyone, […]
Hi everyone,
2002/04/10 09:50
is this an AGP or PCI card?
Reply 28 of 32, by aspiringnobody
feipoa wrote on 2022-02-27, 04:01:
Was the ATI XPERT128 BIOS able to get your Diablotek Rage128Pro working?
I was working a double last night so I’ve not tried it yet. I’m going to have a nap and then give it a go before I go back to work.
The Diablotek has a 40k ROM though so I’m not sure. I may need to append some FFs or 00s to the rom to make it fill the eeprom on the card. We will see what atiflash says when I try it.
astonsmith wrote on 2022-02-27, 11:08:
aspiringnobody wrote on 2022-02-27, 03:16:
It's AGP, sorry should've mentioned that.
No worries! Thanks for being willing to help!
Reply 29 of 32, by aspiringnobody
No dice. Both ROMs flash successfully but the card still doesn't display any video output.
Works in PIII machine though *.*
Reply 30 of 32, by aspiringnobody
aspiringnobody wrote on 2022-02-28, 02:47:
Out of curiosity, does your card boot in 486/PI/PII systems? I have three identical diablotek cards and none of them work in any of my pre-PIII systems. I don't think it's a 3.3V/5V thing because both regulators are on my boards and the chips do heat up. I've also measured vcore at the caps on the back of the Rage 128 chip and had voltage there. ASIC ID 5050 according to atiflash.
Reply 31 of 32, by feipoa
I know the Chinese card ran in my 486, but OpenGL didn't work properly. I don't recall the outcome of the ATI card.
Reply 32 of 32, by matose
Seaside wrote on 2012-03-05, 22:18:
Yes i was looking a BIOS to "fix" a MAC PCI card.
I manage to fix the AGP.
Sorry for the thread necro but how did you managed to fix the MAC AGP card?
I mounted a socket for the BIOS and flashed over 20 BIOS versions with no luck. The VGA card is the traditional 109-63000-00
Thanks
