Reply 40 of 107, by vedmysh
Virtualpilot wrote on 2020-03-09, 10:35:
Unfortunately I've been experiencing CTDs in Jane's F15. […]
First one happened in the first Gulf War campaign mission twice in a row. Missions two and three worked without problems. Then came the first actual real combat mission where you have to destroy SCUD launchers. I got two CTDs near the target site. In my third try I used jump to waypoint option, dropped bombs, but it looks like it screwed my escort planes because I was left there to duke it out with MIG-23s because the promised F-15C CAP was not there.
Other problems: Cockpit starts to flash either in red or green in 2D mode. Changing view fixes it. Happens all the time.
Sound is very distorted after starting the mission but clears about in a minute. If I change the view to external it fixes right away.
Hello.
Can someone else confirm the same problem, please?
Virtualpilot, which GPU do you have? Can you also check GPU driver version, please.
Reply 41 of 107, by vedmysh
Virtualpilot wrote on 2020-04-03, 16:59:
Well I finished both campaigns in Jane's F-15 and installed F/A-18. The game itself seems to work OK but I'm having huge problems in the menus with mouse cursor. I'm seeing two cursors if I see them at all. I'm unable to edit weapons loads for example:
Well, i see the only one cursor in this screenshot...
Anyway, ill check the loadout screen later.
Thank you.
Reply 42 of 107, by Virtualpilot
vedmysh wrote on 2020-04-08, 12:00:
Hello.
Radeon R9 280X, driver 19.9.2.
Reply 43 of 107, by Virtualpilot
vedmysh wrote on 2020-04-08, 12:02:
Well, i see the only one cursor in this screenshot... Anyway, ill check the loadout screen later. Thank you. […]
Thank you.
More examples:
The attachment two-cursors2.png is no longer available
The attachment missing-pilot.png is no longer available
In the second pic I managed to add new pilots but the name is missing.
Reply 44 of 107, by D'Ace
Hi to all, special thanks to vedmysh.
My problem is TSH, I read some of you guys were successful in running F/A-18 with TSH v3 & v4. I prefer vanilla versions, as vedmysh stated, but I'd like to run F/A-18 in more than 1024 x 768. Could you please explain how to install these patches properly? With JSME maybe? just decompressing / overwritting on X:\mydxwnd\f18? I'd apreciate any help on this.
And, I guess I'm not the only one, we DREAM of playing USAF / IAF and why not Fighters Antology. Thanks a lot my friend.
Reply 45 of 107, by Kreshna Aryaguna Nurzaman
vedmysh wrote on 2019-10-23, 07:45:
- Digital Integration Hind (Windows version, Software rendering) and patches (if not integrated into your installation)
- Digital Integration Apache (Windows version, Software rendering) and patches (if not integrated into your installation)
- Digital Integration iF-16 and Afghanistan campaign addon (Windows version, Software rendering)
Can't we use 3dfx patch, or Front Line Fighters version?
Kreshna Aryaguna Nurzaman.
Reply 46 of 107, by Muz
I have problem with FA18, why the camera in the pilot cockpit keeps panning up, and and cannot look forward, when in F1 view?
Also the game lags, with ddraw.dll. Why is that?
Reply 47 of 107, by Hippo
- Jane's F-18 and 1.01 patch
Note: it's only Jane's F-18 I'm interested in.
Hi, I'm playing around with this again and noticed that F-18 seems to work just by installing the game (and apply 101f patch and no-cd exe) and then copy over the following three files from your package into the F-18 game folder:
dgVoodoo.conf
D3DImm.dll
DDraw.dll
The game then runs very well (apart from some minor issues - two mouse cursors, occasional graphical glitches - in the game interface). Since I don't understand what is going on, I just wanted to check whether that's all that's necessary for F-18, as it simplifies and makes for a cleaner install.
Copying the same three files into a "clean" TSH install also appears to work.
Thanks again for all your efforts btw.
Reply 48 of 107, by BEEN_Nath_58
Can anyone explain why renaming .UV2 movies to .UV_ fixes the text in F-15? Technically deleting has also given the same result but what's the issue being cause in loading from HDD?
Reply 49 of 107, by damson
BEEN_Nath_58 wrote on 2022-01-12, 07:34:
It's not an issue of loading them from HDD/CD. The game will not try to load them from the CD when it doesn't find them on HDD, it will not load them at all. And since they break the text, that's what we want.
Re: Jane's Longbow Anthology/Jane's F-15/Jane's F/A-18 compatibility pack
My youtube channel - flight sims new and old
Reply 50 of 107, by BEEN_Nath_58
damson wrote on 2022-01-15, 11:08:
I don't understand this line. I see that if I scroll text in the areas where text is not visible, they can be seen during scrolling. This probably confirms the fact that the text loads, but is not rendered properly. I don't get why text can be rendered when loaded from CD. Probably you can explain it better.
Reply 51 of 107, by damson
BEEN_Nath_58 wrote on 2022-01-15, 12:25:
It's those small video clips played at the bottom (those are that UV2 files) that break the text rendering. If you remove them from the folder (or change their names so the game doesn't find them) they wont be loaded and the text will not be broken.
Reply 52 of 107, by BEEN_Nath_58
damson wrote on 2022-02-17, 15:56:
Which bottom? What I noticed is that the UV2 files load perfectly fine from the CD directly instead!
Reply 53 of 107, by damson
BEEN_Nath_58 wrote on 2022-02-18, 05:23:
Whenever you enter a menu (for instance Training) you will see an artificial horzion in the bottom right corner, to the left of it there is a space where those UV2 animations plays out (i.e. F-15 attacking a target). If you remove UV2 files you should see static picture there.
Reply 55 of 107, by BEEN_Nath_58
damson wrote on 2022-02-27, 10:05:
I hope this video is clear enough
https://youtu.be/QcS-Mfz6jnY
Thank you very much, I see the issue now. Let me hook up with gho to see what's possible to fix both.
Reply 56 of 107, by TheCabal
Ok guys... I'm on to Longbow now but I don't have a copy specifically of Longbow Anthology. Is there another way with LBgold and LB2 copies? After getting F-15 to run (besides IAF, USAF etc.), my brain is short before melting entirely.
Reply 57 of 107, by Njinsa
BEEN_Nath_58 wrote on 2022-02-27, 15:19:
Any luck with GHO getting this movie /menu text bugs on top of his DXWND ?
Thnx.
Reply 58 of 107, by BEEN_Nath_58
Njinsa wrote on 2022-05-02, 22:14:
Thnx.
I have talked about this but he has been busy with other applications. I will quote this text and see if it makes a difference
Reply 59 of 107, by BEEN_Nath_58
There isn't much, till now I could recover the Campaign screen text as well as DirectDraw mode of the game which crashed:
