First post, by Chadti99
So eight of nine of these sram chips arrived to me intact, unfortunately this guy is half missing a few legs. Can this be repaired in some fashion that would work in a dip socket reliably again?
Reply 1 of 3, by weedeewee
solder some pins to it.
In these cases the left over legs of a thru hole capacitor diode resistor or other can be used and trimmed to length.
Do not ask Why !
Reply 2 of 3, by keropi
I have some dead chips that I harvest pins from and solder on top of old broken ones, it works very nice because of that flat surface chip pins have - I solder the good pin+flat surface on top the old flat surface
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 3 of 3, by mdog69
Buy a turned pin IC socket, push the good pins of the IC into it, then use a soldering iron to solder the stubs of the broken pins onto the socket pin.
Turned pin sockets are usually made from glass filled insulation, and the pins offer more surface area to solder to.
The downside is that when you insert a turned pin socket into a non-turned pin IC socket, you tend to spread the contacts, meaning if you find a replacement IC with a full set of pins the stretched socket may not grip it properly.
