First post, by vkcpolice
Hi All Ive come across an issue with jazzjackrabbit holiday. It won't let me copy the game from my cd to my hard drive it keeps throwing up an error that a ini. File is missing and it can't copy. I get the same error under win 3.1 using file manager
Is it a hidden file or something please see pic
Reply 1 of 8, by konc
Yes there is this weird .ini file which has no name but only an extension that confuses dos copy. Later windows versions copy/xcopy can handle this.
Omit this file and copy the rest, the game runs just fine without it.
Reply 2 of 8, by vkcpolice
How do I do that?
Reply 3 of 8, by konc
From windows file manager just don't select to copy that particular file, like you'd do in modern windows
From dos if you don't use any file manager like norton commander you can copy the files in groups
copy sounds.* d:\...
copy sprites.* d:\...
copy *.psm d:\...
until you copy everything except the .ini
Reply 4 of 8, by vkcpolice
That file won't even show up under win 3.1 file manager
Reply 5 of 8, by konc
Just copy specific individual files and not *.*
Reply 6 of 8, by Azarien
Use Necromancer's Dos Navigator for example...
Reply 7 of 8, by Jo22
Hi. What CD-ROM driver is being used?
I once had similar issues with vide-cdd.sys loaded high.
Reply 8 of 8, by vkcpolice
i copied it. thanks all i managed to find the ini file in win 3.11
