Reply 21160 of 30918, by davidrg
Shreddoc wrote on 2022-03-07, 20:48:
It's fascinating to see Win95 run without a local hard drive in that manner.
Now we just need to do it over the internet.
"Windows 95 machine in New Zealand, boots fr0m hard disk in USA". That's a headline. (Take the world's attention off this pesky political stuff that's for sure. 😁 )
That would be something to see!
If you want to see what it looks like booting from the LAN I got out my IP-KVM and made a quick recording:
https://www.youtube.com/watch?v=9mOgDrJwWP4
Video performance isn't great - I'd really need some sort of VGA to HDMI converter and some sort of HDMI capture device if I was going to make a habit of this.
Reply 21161 of 30918, by creepingnet
Got my 387SX in the mail today, well...I guess it's official now, Links for DOS runs on the minimum system requirements of a 386SX with a 387SX. So my guess was right the engine that handles security on Links does use the 387 for TLS/SSL/etc. Oldest TLS 1.3 compatible PC I've ever heard of.
~The Creeping Network~
Reply 21162 of 30918, by BitWrangler
I was just reading the CD case of "Links: The challenge of golf" for DOS and wondering what the heck you were talking about because it says right there it runs on a 286..... then I realised you were talking about the text mode web browser 🤣
Reply 21163 of 30918, by Kahenraz
davidrg wrote on 2022-03-07, 19:47:
IIRC Microsoft did recommend having a local disk to store the swap file if possible. I guess with a local swap file performance would probably improve a fair bit - the NIC is only 10Mbps or around 1MB/s so its kind of amazing windows runs as fast as it does. Wikipedia says IDE was originally only 8.3MB/s half-duplex so I guess with a 10/100 card you could probably beat that (assuming the server has fast disks).
OS responsiveness is all about latency not just throughput. And there is a whole lot of latency added by the network. A spinning disk swap file as cache would be much faster for any kind of moderate swap use.
Reply 21164 of 30918, by creepingnet
BitWrangler wrote on 2022-03-08, 02:59:
Well....text and graphical....people get really confused because there's a Lynx text mode browser, and then there's a Links (links.twibright.com) browser, the latter is what I use. I tend to rely on Links on my old machines to download stuff to them that way I don't have to always be pushing stuff from a modern machine via filezilla. Unfortunatley I don't think it works on anything older than a 386SX though, tried it on the Tandy and on the GEM and did not get anywhere IIRC. Might try again on the GEM though.
Reply 21165 of 30918, by BitWrangler
I wasn't realising Links v2 was much enhanced from the Links I used years ago http://www.jikos.cz/~mikulas/links/screenshots/jpg.html which is very similar to Lynx.
Reply 21166 of 30918, by dormcat
Tried installing Win10 on three cleaned vintage systems: two Wolfdale Pentiums and an i5-4460. The i5 and one E5500 went smoothly, but the E5700 refused to boot from Win10 USB flash drive. Strangely, the MemTest86 flash drive worked perfectly on that E5700, meaning either the port or the controller were fine. Still can't figure out the cause; maybe I'll try using a DVD instead.
UPDATE: Silly me, BIOS took that flash drive not as "removable device" but as a secondary HDD. Who wrote that BIOS options......
Reply 21167 of 30918, by BitWrangler
IIRC USB in legacy mode may take USB stick as HDD.
Reply 21168 of 30918, by dormcat
BitWrangler wrote on 2022-03-08, 16:21:
But MemTest86 would run from flash, probably because MemTest86 would pretend the flash drive as a floppy (even have the exact 1,457,664 bytes of total capacity).
The BIOS only allows three categories of boot devices: HDD, optical, and removable (e.g. an USB floppy drive), with the flash drive and the actual HDD/SSD under the same "HDD" category. What a strange design. 🙄
Reply 21169 of 30918, by BitWrangler
Yah, there was some weirdness out there, I had PIII and Athlon systems boot off USB perfectly, then there seemed like there was some stupidity in early core and A64 era where support went retrograde and was a pig to work with... then it all smoothed out again.
Reply 21170 of 30918, by bjwil1991
Had to reinstall the Compaq VDU CGA card since my Portable 286 is having issues with any EGA card I install, even though the BIOS supports it.
I might get the up-t0-date BIOS and see if that fixes it, but for now, the CGA card will do. In other news, I trimmed the CRMC-LU005S drive so I can eject the drive and insert a CD for the Portable 286 and it works (except one CD doesn't work) and I'll test it again later on once I get a new 6V lithium.
Reply 21171 of 30918, by TxSnipper
Kahenraz wrote on 2022-03-07, 02:14:
That computer looks amazing! Job well done rescuing and restoring such a relic. Can you explain more about the hardware and what kind of software was used on it?
The demo in your photos is also very impressive and looks wonderful on the green phosphor. Are there any videos of it? Does it animate or just draw things?
Thank you, the system has a single board solution 1x z80A (4Mhz) using 64K Ram,(green area below) the graphic power uses another 1x z80A CPU with 32K (red area)ram and HD46505 graphic processor( Yellow area) and runs a 4K ROM on it.
the board looks like this., and I admit I have not found much on it aside from a single CPM 2/.2 floppy the software "demo" was a SBASIC demo.bas file to show off the high res graphics it could do. The Mainboard looks like this. and as you can see it has 2 sets of connectors for floppy drives 5.25" or 8" drives directly from the mainboard. the one I got has the 2x5.25" 80 tracks DSDD (also known as QDDS Drives) 720K
Main PC: 8700K, 16GB, RTX 2060, 2x500GB SSD, Asus 370 Gaming, 2x37"LG Monitor
Work PC: Quad 9400, 8GB, 240GB SSD, 1TB HDD, GT720
Retro PC: TRS-80 Model 4, 2x 360KB, 1x 720KB, 1x Gotek, FreHD 4x4MB HDD, RS232C-Wifi Modem
Reply 21172 of 30918, by Zeerex
Improved memory speed of my SIS 5598 M5SIB via my first experience with WPCredit and using a data sheet for that chipset. Was able to improve float FPU from around 100 stock to 136mb/s. Which is of course pretty slow compared to a highly tuned MVP3. Largely followed the recommendations on k6plus.com for the SIS530 as there isn’t as much love for 5598 out there. It may not be the fastest K6 experience but I’m really digging it.
Reply 21173 of 30918, by BitWrangler
Nice, if you figure out how to save out the PCR file or whatever, I'd be interested. I have an M571 that's gonna get one of those K6-2+ modded to 3+ annnnd it could use the help. (Not my fastest super 7 btw)
Reply 21174 of 30918, by TrashPanda
BitWrangler wrote on 2022-03-10, 05:02:
I got a VA 503+ sitting in the box waiting for a modded K6-2+, still haven't got a nice case for it yet.
Im thinking of something like this
The attachment s-l1600.jpg is no longer available
Only issue I have is .. well finding a place for something this dang big 😁
Reply 21175 of 30918, by Kahenraz
That case is glorious. I love it.
Reply 21176 of 30918, by TrashPanda
Kahenraz wrote on 2022-03-10, 09:03:
Its gloriously huge and Im still debating if its worth having it as part of my permanent collection, I really dont have any room for a Super Tower but ...I wants it, ITS MY PRECIOUS !
Reply 21177 of 30918, by Kahenraz
I'm in the same boat. I would really like one of these old Gateway 2000 towers, but I would have nowhere to put it.
The fact that the one you've picked out has two 2.5" bays is very attractive. You can put dual floppies or a floppy and a card reader.
The attachment vintage-gateway-2000-p5-133-gaming_1_b22c3ecb1f017c643f30daa603765ce3.jpg is no longer available
The attachment vintage-gateway-2000-gaming-computer_1_bbd48d7605d8bd46196f0bd17a36756c.jpg is no longer available
Reply 21178 of 30918, by TrashPanda
Kahenraz wrote on 2022-03-10, 10:06:
I'm in the same boat. I would really like one of these old Gateway 2000 towers, but I would have nowhere to put it. […]
mhm 6 5.25 bays is super nice too, I would have to invest in some long cables to use it and it would look hilarious with a baby AT in it but ...all that space is alluring, but to install more than two HDDs in it I would need to do a bit of sheet metal working and make some HDD cages for it.
Due to its age it doesnt come with any extras but it does have a ton of space behind the 5.25 bays to install a fan and HDD cage.
Reply 21179 of 30918, by Kahenraz
With all of those bays you could instead add hot-swappable 2.5" or 3.5" and maybe even a CompactFlash bay, instead of adding more internal drives.
If you plan to use SSDs then Velcro would work just fine. And CF cards in adapters can be seated directly into the slot without needing any cables.
For a modern retro machine, I don't see any reason to use a spinning disk, unless you're after the aucusics.
My only recommendation would be to put wheels on it. Once you've got it fully loaded you may not be able to lift it. I know this from experience. 😀
