Reply 280 of 600, by Sphere478
I still wanna know what happens when those missing SMD spots are populated. There is a even earlier chip than that one you pictured that has most of the spots left unpopulated.
Unfortunately I think we could possibly learn something from a de lidded database.
Might be able to find some interesting pad configuration variations
Sphere's PCB projects.
Reply 281 of 600, by Deksor
Mod is successful on my side as well !
Thanks a lot for discovering this mod everyone !
1.45 MiB
1.99 MiB
1.55 MiB
Reply 285 of 600, by Deksor
No, I don't think thermal is that big of a deal for those chips. Especially in the conditions we're gonna use them. I mean they were designed to be used in laptops with potentially bad cooling, whereas now they're used on desktop motherboards with beefier coolers 😀
If I wanted to do some heavy overclocking that would probably be a bigger concern though (maybe other mods could be made for those chips for cooling ?)
Reply 286 of 600, by Nemo1985
There wasn't any dried thermal compound under the lid?
I think it's a good idea to change it, to my experience the best for such things is the Artic Silver 5, it didn't dry in like 7 years on my old pc.
600 is a good overclock and ideally the limit of k6 architecture so very good work nonetheless 😀
Reply 287 of 600, by Deksor
Well I'm not sure it's actually dried thermal compound. I wonder if it's not some kind of thermal glue (Or maybe it became like glue after 22 years). Maybe I'll replace it at some point. But so far so good.
Reply 288 of 600, by Sphere478
I’m still trying to figure out what exactly that stuff is.
The hardscape stuff I found isn’t quite the same but looks similar.
It is adequate enough at thermal transfer though.
I really want to get ahold of some artic silver thermal epoxy.
Stupid ebay seller that sold me the other epoxy didn’t send both tubes.
If anyone has the ability to look up pattents or whatever and figure out the glue used please do tell.
Reply 289 of 600, by cyclone3d
The Arctic Silver epoxy has not been made in ages. My guess that the hardener in any stuff that is still around has gone bad.
On top of that, thermal epoxy is not going to have anywhere near the same thermal transfer ability as good thermal paste.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 290 of 600, by BitWrangler
AS supposedly still make the epoxy for industrial customers. IDK if eBay dudes are just breaking cases intended for that or have ancient stock.
Reply 291 of 600, by Sphere478
BitWrangler wrote on 2022-03-09, 01:42:
I think I may know what amd used.
Not urethane, but polyurethane.
Reply 292 of 600, by BitWrangler
You're starting to worry me if you're gonna put that on the core... at least use something vaguely appropriate for that like STAR-922 or JB Weld even (Which at least has performance in the range of low end thermal paste)
Reply 293 of 600, by Sphere478
BitWrangler wrote on 2022-03-09, 04:25:
that's for the lid
this is for the core:
    12.31 KiB
Reply 294 of 600, by cyclone3d
Why would you use epoxy on the core?
Other than making it sure that you will never be able to remove the IHS again there is no point.
YMF7x4 Guide
Reply 295 of 600, by Sphere478
cyclone3d wrote on 2022-03-09, 04:49:
in theory you wouldn't have a need to remove it again. thermal paste will age. it's either epoxy or use the same adhesive as used for the IHS it seems or pull the lid every 10 years. but in 10 years will you remember? idk. paste is non perminant and may be washed away when cleaning it just seems like the wrong approach under a IHS
what did p4 use? did it use paste?
edit:
https://www.techpowerup.com/forums/threads/pe … -solder.255672/
maybe it's fine...?
Reply 296 of 600, by cyclone3d
I've never delided a Pentium 4.
I have however taken a heatsink off of a CPU 15 years after the cooler was put on and found that the AS5 is still like new and still just as much of a pain to clean as it always has been.
The higher end pastes that don't dry out are going to be fine for 15-20 years at a minimum.
AS5 is not even a high end paste anymore in regards to thermal transfer. I saw a real review of it a few years ago and it was sold as having a way higher thermal transfer rate than it actually has.
YMF7x4 Guide
Reply 297 of 600, by Sphere478
cyclone3d wrote on 2022-03-09, 05:09:
I've never delided a Pentium 4. […]
you have swayed me, what is the best stuff to use for a long term application? link, pic ( to ad to guide)
Reply 298 of 600, by RaiderOfLostVoodoo
Recently upgraded my parents computer.
Prolimatech PK-1 still creamy after about 11 years.
Reply 299 of 600, by Tetrium
AS5 was always overrated imo. And a pain to clean as well compared to well, virtually all other TIMs out there at the time as long as it wasn't some kind of epoxy 😜
My retro rigs (old topic)
Report spammers here!
