First post, by Cuttoon
Sorry if it's old news, but just stumbled upon this:
https://www.ebay.com/itm/313842685211
While I'm rather confident I could build one from scratch, this looks like a good deal, icluding the toslink. Any experience here?
I like jumpers.
Reply 1 of 6, by kolderman
Eh way to expensive. Any old toslink bracket should be easy to wire up.
Reply 3 of 6, by Cuttoon
kolderman wrote on 2022-03-14, 20:56:
Thanks, I get the sentiment, but then again - it's both that and coax in one clean, piece ready to install.
Not to contemplate the exchange rate between Chinese and German work-hours too much, but let's assume it's nice to have - will it work, to hook up an old Onkyo surround amp?
I like jumpers.
Reply 5 of 6, by Joseph_Joestar
I recently built one. It was easy as pie, despite my soldering skills being pretty mediocre.
Don't expect too much from the SPDIF output though. You'll be able to record AWE music just fine, but digitized sounds won't go through SPDIF unless the game specifically uses 16-bit 44.1 kHz sound samples.
Reply 6 of 6, by Cuttoon
Joseph_Joestar wrote on 2022-03-14, 22:10:
...which will rarely happen in contemporary games as even Half-Life stuck to 8 bit 11 kHz, IIRC.
I see... sounds like some fancy feature on a creative labs card. Like, 16 bit sound per se with the added bonus of not being fully backwards compatible to SB pro. Wow.
Thanks!
I like jumpers.
