First post, by UltimateElectronic
I've got a TNT2 M64 floating around and someone has a Socket 370 ASUS motherboard (I think it's a CUSL2, based on the photos) they're going to give to me which has a Pentium III 866.
I know that the TNT2 M64 was more of a budget card in comparison to the TNT2 but apparently the difference in performance is negligible compared to the TNT2 from what I've heard.
Was the TNT2 a high-end card when it released? And is it a good GPU to go with a Pentium III 866?
Reply 1 of 54, by Doornkaat
The regular TNT2 is quite a bit faster than the TNT2 M64, mostly because it has more than double the VRAM bandwidth.
As you said the TNT2 M64 is a budget card from 99 while the Pentium III 866 is one of the fastest Coppermine Pentium IIIs and released in 2000. There's certainly a bit of a mismatch going on. If you bought your computer for gaming you would probably not have combined those two. If you wanted a computer mostly for 2D applications it would have made sense though.
Still a TNT2 M64 is a good enough entry level Win9x gaming card and if you already have it you can't go wrong with it. If you feel you need more performance you can upgrade any time.
Edit: And yes, the TNT2 was part of Nvidia's high end segment when it launched.
Reply 2 of 54, by shamino
If you want to get everything you can get out of the video card you already own, then a P3-866 should easily push it to it's limit. Some would call that a "bottleneck", but we could also call it "maximization".
The M64 will be a strongly limiting factor in 3D games but at least that leaves an obvious upgrade path if needed/wanted.
Reply 3 of 54, by Tetrium
the TNT2 M64 is quite underpowered for a Coppermine 866. I used to have a TNT2 M64 in a Celeron 400MHz before I disassembled that system.
It will probably work just fine with the Coppermine, but would fit more closely to something like a Pentium 2 350MHz or so.
Like I said, it will work fine and this way you have a potential upgrade to look forward to 😜
My retro rigs (old topic)
Report spammers here!
Reply 4 of 54, by flupke11
A Geforce 2 GTS would be more suitable, period-wise. But in the end, it's your call. I had an M64 coupled with a Celeron 500 on an already "old" P2L97 in 2000. It did its job though, and I have fond memories of that system.
Reply 5 of 54, by leonardo
UltimateElectronic wrote on 2022-03-14, 05:13:
What these guys said. If you had a TNT2 on a system such as this, it should at least be a regular TNT2 or the TNT2 Ultra. More likely though, you'd pair a system such as this with a GeForce 2 or GeForce 3-class GPU if you wanted something well balanced - or a GeForce 4 or a Radeon 9x00-series if you wanted maximum performance. Anything much later than that and the bottle-neck will be clearly reversed.
I have a GF3 Ti200 in my 1 GHz PIII system, and these two are best buds. 😀
[Install Win95 like you were born in 1985!] on systems like this or this.
Reply 6 of 54, by PARKE
Here an M64 review:
https://www.anandtech.com/show/393/12
Reply 7 of 54, by AlexZ
Riva TNT2 M64 is only good for testing unknown boards. Get GeForce 2/3/4/FX.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
Reply 8 of 54, by UltimateElectronic
leonardo wrote on 2022-03-14, 14:23:
Well, I've got a couple of MX440s floating around the place that could go in there. I'd imagine those would make it a pretty maxxed out Pentium III rig. ։D
Reply 9 of 54, by UltimateElectronic
AlexZ wrote on 2022-03-14, 19:20:
Alright, will do. I have a couple of MX440s floating around so from what I've gathered, one of those would be a better bet.
Reply 10 of 54, by UltimateElectronic
Reply 11 of 54, by UltimateElectronic
PARKE wrote on 2022-03-14, 16:05:
Here an M64 review:
Thanks for that!
Reply 12 of 54, by UltimateElectronic
flupke11 wrote on 2022-03-14, 14:23:
Fair enough. I have another Celeron 433 computer that has integrated SiS graphics and unfortunately doesn't have an AGP slot... Still quite miffed about that ։P
Reply 13 of 54, by UltimateElectronic
Tetrium wrote on 2022-03-14, 14:19:
Ahh ok, fair enough. I think I had a TNT2 M64 in something a while ago, but I don't remember what happened to it.
I've decided to go with an MX440 as I have some of them around the place.
Reply 14 of 54, by UltimateElectronic
shamino wrote on 2022-03-14, 09:47:
Maximisation. I like that ։P
Yeah, I had been told that 3D games wouldn't work hugely well on it if at all...
Reply 15 of 54, by UltimateElectronic
Doornkaat wrote on 2022-03-14, 05:29:
The regular TNT2 is quite a bit faster than the TNT2 M64, mostly because it has more than double the VRAM bandwidth. As you said […]
Alright fair enough. Looks as though it's probably an imbalance for gaming from everyone here is saying.
As I don't have a GF2 or GF3, my plan is to go with one of the MX440s I have that aren't in anything... I'd imagine that it'd create more of a balanced system for gaming.
Reply 16 of 54, by Doornkaat
The GeForce 4 MX 440 is a very fitting card for this motherboard CPU combo.👍
Reply 17 of 54, by Tetrium
UltimateElectronic wrote on 2022-03-17, 00:57:
My Celeron 400 rig not having AGP is one of the reasons I put a TNT2 M64 PCI in there in the first place 😜
I don't think I had a Voodoo 3 back then, but a TNT2 M64 PCI I did have. This was basically the very first PC I ever build myself so I had to make due with what I had at the time.
Reply 18 of 54, by Tetrium
UltimateElectronic wrote on 2022-03-17, 01:00:
I think the GF4 MX440 is an excellent match for your CPU 😀
As a bonus, it should produce relatively little heat (and hopefully little noise as well) so depending on how retro your PC case it (older cases had much poorer cooling in general), your cooling will probably work fine if it already did.
Reply 19 of 54, by The Serpent Rider
Depends on what you consider as underpowered. TNT2 M64 can be easily bottlenecked by PIII-866 in 640x480 mode with 16-bit color.
