Reply 20 of 177, by Spikey
- Oldbie
The Yamaha GS implementation certainly isn't something I want to get caught on. But I would like it recorded. I do miss my MU2000EX!
Found out that the JV-50 operates in 18-bit mode, so given it has other extra components, it's a slightly higher quality SC-55mkII, potentially the second highest SC-55 for output quality. With the highest quality probably being the CM-300 and its BurrBrown PCM61, although I'm not sure about the other components.
(Sub Board Assembly Lower-Middle),
(Sub Board Assembly Middle).
