Questions about a CMS-401 MIDI card
Reply 20 of 27, by cricket
cyclone3d wrote on 2020-07-31, 21:07:
cricket wrote on 2020-06-24, 19:59:
I also have a board that has no cable and it also doesn't get detected.
Any chance to get the pinout of the cable?
I've got one of these cards on the way... One of the few MPU-401 clones I didn't already have. I'll post the pinout once it arrives
Has been a while...
Did the card arrive? Is it working?
Reply 21 of 27, by cyclone3d
cricket wrote on 2020-10-18, 19:39:
Has been a while...
Heh.. it did arrive. Forgot about the thread. You still need the pinout?
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 22 of 27, by cricket
cyclone3d wrote on 2020-11-07, 06:25:
Has been a while...
Yes, the pinout would be highly appreciated. 😀
Reply 23 of 27, by cyclone3d
I completely forgot about this.
Here is the pinout:
Connectors:
The attachment midiconnfront.jpg is no longer available
The attachment DB-25.gif is no longer available
DB-25 male is solder side
Pinout:
First number is the DB-25 pin number.
RCA (Metronome Out):
12 - RCA center
16 - RCA ground
Red Din-5 (MIDI OUT)
1 - Din pin 5
2 - Din pin 4
14 - ground (Din pin 2)
Black Din-5 (MIDI IN)
3 - Din pin 5
4 - Din pin 4
15 - ground (Din pin 2)
DB-25 other
8-9 shorted
10-11 shorted
The manual says that the computer will not detect the card unless the cable is plugged in. I am guessing this is what the 8-9 and 10-11 pin shorts do.
You are also not supposed to plug or unplug the DB-25 connector while the computer is on.
YMF7x4 Guide
Reply 24 of 27, by adi
thanks
my cms-401 got a second life 😀
Reply 25 of 27, by Cuttoon
Still have the "CMS-401-II" edition of that card.
Uploaded a scan of my manual here:
Re: Intelligent mode MPU-401 and how it's utilised.
Not sure any more about the similarites between that an the original model, but maybe it'll help somehow.
I like jumpers.
Reply 26 of 27, by cyclone3d
I actually have two different versions of the CMS-401 now. One has no jumpers so the base address cannot be set. The other has jumpers.
I'll have to scan the documentation that I have though there really isn't that much to it.
YMF7x4 Guide
Reply 27 of 27, by henris42
BTW I have CMS-401 first version card, I believe the jumper diagram in version II manual is reversed for the address. (you need 2 jumpers to have it in 330h).
