First post, by mrzmaster
Hey all,
I recently completed a build based around an Asus TUSL2-C and 1.4GHz Tualatin and everything seems to be running swimmingly, however, upon boot I receive the message (see attached):
<BIOS:> BIOS update data incorrect. CPUID=000006B4
The attachment bios_message.png is no longer available
Does anyone know how to fix this? It looks like the board is running BIOS version 1007.A.
Thanks!
Reply 1 of 10, by Doornkaat
Is this the original EEPROM?
Reply 2 of 10, by mrzmaster
Doornkaat wrote on 2022-03-24, 20:52:
Presumably so, although I don't know for certain since I bought the board used (of course). It appears to be PhoneixBIOS chip, marked "D888 BIOS" with a date of 1998. So.. probably?
Reply 3 of 10, by Doornkaat
Ok, have you tried (re)flashing the latest BIOS and then resetting the BIOS settings to default?
BIOS and flash utility are still avaliable on ASUS' website.
Edit: I just asked about the EEPROM because even though I don't exactly understand why there seem to be differences between EEPROMs that are supposedly interchangeable that cause similar errors.
Reply 4 of 10, by Grem Five
I think I have seen a website out there where someone has made a patched bios for the TUSL2-C.
I get the same message on my system but as it seems to function just fine I havent ever worried about it.
Reply 5 of 10, by mrzmaster
Grem Five wrote on 2022-03-24, 21:07:
Probably this one? Yeah.. I'm a bit scared to try an unofficial BIOS like this. 😀
That's the thing, if it's just cosmetic, should I even bother with flashing?
Just curious, what BIOS version are you running on your board?
Reply 6 of 10, by mrzmaster
Doornkaat wrote on 2022-03-24, 21:01:
I haven't yet. It looks like BIOS 1012 is the latest non-beta version on Asus's site. I suppose I could give that a try.
Reply 7 of 10, by Doornkaat
mrzmaster wrote on 2022-03-24, 21:11:
I suppose then it's actually simply about the 1.4GHz Tualatin being newer than your current BIOS. Fingers crossed!😃
Reply 8 of 10, by mrzmaster
Whelp, I flashed successfully to 1012, but it's still showing the BIOS update data incorrect message on boot.
Reply 9 of 10, by Towncivilian
The BIOS is lacking CPU microcode for your processor’s CPUID. It can be corrected by flashing a modified BIOS that contains the appropriate microcode. I don’t know if one is readily available, however.
abit BX-133 RAID, P3-S 1.4Ghz, 768MB PC133, Radeon 9000 PRO, AWE64, 2x40GB RAID1, Sony SDT-9000 & Connor CTD-8000 SCSI DDS2 DAT drives, Realtek 8169 1GB NIC, Adaptec DuoConnect AUA-3121, Win2k SP4
Depeche Mode Live Wiki
Reply 10 of 10, by Grem Five
mrzmaster wrote on 2022-03-24, 22:21:
Yeah I guess you found out... mine is running 1012 as well, sorry for the late response.
I dont know if there is any problems without the proper microcode updates but I have been running my system for 1.5 years and havent noticed anything. Maybe leaving a bit of performance on the table but havent noticed it, only way to check is compare it with my Tyan Tomcat i815T S2080GN which bios I *believe* has the microcode for the 1.4-s.... at least I dont remember seeing an error on boot up like I do with the TUSL2-C.
In old AnandTech article they had the TUSL2-C a bit faster than the Tomcat guess maybe some day I can get around to testing that (maybe in 10 years) since they both have the same processor in them.
