First post, by extent
I would like to try and find out how to enable gravis ultrasound music within "dosbox game launcher" for games that have this ability? I have downloaded the necessary gravis set, renamed it (GRAVISSND411) to ULTRASND, and changed DBGL's target directory settings for gravis to where it is now located, at C:\ULTRASND\. I have enabled gravis in DBGL. Supposedly some games such as heretic and doom as an example require that I have installed the General MIDI patch set from 2.06a or above. The set I have uses 2.1, located at C:\ULTRASND\MIDI. In Dos Box DBGL, I can click on "run setup" which runs an original games setup. For Music and FX I choose and save Gravis as default. The problem is that with all games that can use gravis in DBGL, no music can ever be heard, only the sound effects. Some forums have mentioned that all other audio settings should be turned off (disney sound service+other soundcard options), the audio GF1 IRQ in DBGL should be less than 8, and that I may need to copy ULTRAMID.INI from gravis into the games directory, and rename it to DMXGUS.INI. Some games supposedly cant find the gravis files unless they are set to C:\DOS\ULTRASND, but I have tried all of these options, and nothing seems to work for enabling the music.
I have tried many different setup combinations. I dont need to know how to enable gravis using dosbox alone,
only through dosbox gameslauncher. Perhaps I need a different target directory for the files, or some
vital files are missing? If anybody wants to try and get it working, DBGL can be found at
http://members.quicknet.nl/blankendaalr/dbgl/ and a link to the 'Gravis ULTRASND Files'
folder was posted on here before (not the 'GUS Install' pack).
Thanks for any help 😀
