Reply 21300 of 30918, by TrashPanda
ODwilly wrote on 2022-03-27, 08:27:
TrashPanda wrote on 2022-03-27, 07:47:
Out of curiosity does anyone here have experience with Ark Logic Video cards >?
I've been offered a pair of them an Ark 1000PV and a Ark 2000MI, I dont know much if anything about where the Ark based cards sit in regards to DOS or what other cards perform on a similar level.
If you look them up around here they seem to be great for DOS but absolute garbage for Windows Acceleration
hmm
Garbage Windows acceleration isn't an issue if their DOS performance is solid, always nice to have a few good DOS video cards to use.
Seems the 1000PV is a great DOS card and the 2000MT is just as good, might give them both a whirl in my DOS rig.
Reply 21301 of 30918, by davidrg
I spent a bit of time today doing some programming on my 486DX4-100 using Borland C++ 4.5 under Windows 3.11. This would be my second ever DOS program (in C) - the previous one being something to output my current IP address as DHCP flashes by too fast during startup to easily catch the output.
This program figures out if NZ Daylight Savings Time is currently in effect - this because the DOS SNTP client I use doesn't do daylight savings time; you've got to pass in the UTC offset on the command line. And I don't want to edit my autoexec.bat twice a year. So now the right thing should just happen automatically on startup - something I'll get to test on the 3rd of April.
Reply 21302 of 30918, by 386SX
Lately still optimizing my netbook oriented mini-itx dual Atom SoC to work as fast as it can on Win 8.1. The GUI reduced to the lightest possible configuration and using most of its DIrectx9.0c integrated smartphone oriented SGX545 GPU to "accelerate" gui and games. Not as bad as might be expected. Testing games like Far Cry with 800x600 at medium level details is almost playable and similar would be on Doom3. Considering this iGPU basically has almost no power impact at the plug when stressed (maybe a couple of watts) it's interesting. An external video card on PCI can increase the compatibility and final speed as tested with the Geforce 210 or GT610 (on PCI only) but I wanted to keep the compact mini-itx case.
Interesting to see ATi tech demos for 9700/9800 cards running on this hw almost smooth. Generally I'd say that beside the very weak CPU it's still GPU limited monitoring the cpu usage. But as GPU-Z reports, it has 4 Unified Shaders and 2 ROPs and 4 TMUs on a 400Mhz clock and using shared 1066Mhz DDR3 memory.
Reply 21303 of 30918, by Joakim
Been playing around with Amiga emulators on a raspberry pi 400. Amiga for me was just games though so I feel lost in workbench..
Reply 21304 of 30918, by cyclone3d
Swapped out the tired stock cooler on my Slot-1 Pentium 1000 100/256 CPU with a nice new shiny thin finned one with copper heatspreader. Used Arctic MX-5 for the paste.
It seems like it is going to run just fine at 1.12Ghz in the GA-6BXC motherboard I put it in though I will most likely try one of the modded BIOSes as they are supposed to fix some stuff with the OEM BIOSes.
Also put that motherboard into an old Dell Dimension XPS case in preparation for building a system to test out PCI sound cards. It will also end up being a full build.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 21305 of 30918, by andrewreader
Joakim wrote on 2022-03-27, 21:44:
Don't feel lost.
There's so much you can do in Workbech.
You can enjoy the pre-emptive multitasking, by running multiple things at once, the speech reader, the bouncy ball thing, a notepad editor.
You can use WHDLoad to launch games and demos from Workbench.
You can make your own icons for things; check out the icon for launching Monkey Island for example.
And look at Workbech through the ages on YouTube up to the present day. It's done well.
Reply 21306 of 30918, by appiah4
This was useful to me when I was getting back into the Amiga.
https://www.youtube.com/watch?v=mjBU3y4IHTM
Reply 21307 of 30918, by H3nrik V!
appiah4 wrote on 2022-03-24, 10:24:
I am trying to remove the HSF from a PII-350 I own so that I can mount it on a PII-400 I recently purchased. However, there is a problem: I can't seem to figure out how to remove this bolts/screws that have it tied down. Are these small allen key screws? Are they torx screws? Anyone have experience with removing and remounting these?
Check out this thread about said type of cooler.
Re: Pentium 2 SECC heat sink removal
As a side note, one of my allen keys are now permanently twisted 🤣 it's that tight they are ...
Reply 21308 of 30918, by stef80
appiah4 wrote on 2022-03-25, 10:51:
stef80 wrote on 2022-03-25, 08:40:
appiah4 wrote on 2022-03-25, 08:09:
Yeah, I tried oil as well as WD40 to break the rust and that inhuman grip, but it only worked on two of the screws. That thing is bolted onto there by Thor himself.
Don't do it. Just find one with SECC2 cooler.
I actually just found a Pentium II 450 which worked out even better for me; now my 1998 build has the best CPU that was available that year. (I only had a PII-300 😀 )
Great find 😀. Easily serviceable with massive Foxconn heatsink. Have 2 just like yours, Compaq branded.
You can attach regular, slow moving 80mm fan there with no problem:
The attachment 20220319_120039.jpg is no longer available
Reply 21309 of 30918, by Merovign
Huge project weekend, couple more mobos for testing dozens of video cards for DOS. Became kind of a technical nightmare with trying to use a CF/IDE adapter, which I gave up on after about three hours. It seemed to be actively sabotaging, no matter what changes I made to the configuration, it would try to boot to CF if it was plugged in, so I couldn't reformat it or copy files. UBCD could see it but nothing worked. My Conner 1gb drive seems to have died in the process as well.
The Gateway P2 233 is kind of amazing, perfect balance of old and new features for a late non-speed-sensitive DOS machine. USB as well.
Finally used a Fujitsu drive and got the 486 running, after a lot of config headaches, though after testing a few cards I got a memory parity error and packed it in for the day.
I went to Goodwill and got a C64 modem for $2.50 though, and a few other things. They never have computers anymore, anything interesting just happens to have slipped by the sorters.
*Too* *many* *things*!
Reply 21310 of 30918, by appiah4
Downgraded my Cx5x86 PC from Win95C to DOS/WfWG. Feels so much more right. Also installed mTCP and now I can transfer files to/from it easily. Also played a bit of Dune II. One of the few games I know where the FM Synthesis soundtrack is far superior to the MT-32/General MIDI ones.
Reply 21311 of 30918, by Kahenraz
Merovign wrote on 2022-03-28, 10:09:
I don't know what the issue is exactly, but I have problems with trying to use CF cards as IDE drives if they have ever been formatted in Windows. Even Partition Magic for DOS reports and error with the partition table and won't allow any actions to be performed on it.
I am always able to fix these issues by booting to a floppy, deleting the partition using fdisk, and formatting it there. Then it will recognize properly in Partition Magic, DOS, 9x, and boot properly from the BIOS. It's also recommended to use "fdisk /mbr" to ensure that the master boot record is written properly, just to be certain. This procedure has always worked for me, even on the most stubborn of CF and SD cards.
Reply 21312 of 30918, by Joakim
andrewreader wrote on 2022-03-28, 05:32:
Don't feel lost. […]
Don't feel lost.
Hehe great tip, "don't feel lost". Why didn't I think of that! 😁
Thing is, I only had an a500 and I was 7 😀
appiah4 wrote on 2022-03-28, 05:33:
Cool I'll look into that.
Reply 21313 of 30918, by Merovign
Kahenraz wrote on 2022-03-28, 15:27:
Well, this CF is brand new (though a small 256Mb) and fdisk won't detect it, though the BIOS does. Actually I tried several partition utilities, drive scanners, etc... The CF could be defective but I haven't had time to put *another* system to check it. I tried 3 adapters.
Fdisk says "invalid drive designation."
Reply 21314 of 30918, by BitWrangler
Smells like you need to use that util for changing it from removable drive.
Reply 21315 of 30918, by schmatzler
I reflowed the memory chips on a Radeon X850XT (AGP) with my hotair station. The card was giving me issues with black squares randomly popping up on the image.
The previous owner had covered almost all of the memory chips with small heatsinks. Except two of them - why this decision was made, I don't know. Maybe he ran out of them...
Reflowed them both, put brand new thermal tape and heatsinks on them and...all the issues are gone! I'm happy I did not have to go the full reball route.
Another card saved from the trash. 🥰 This will make for a killer 98SE build. I just need a quiet and powerful fan now. My Zalman OP1 is driving me crazy at 12V and running it on 5V barely keeps this card cool.
Reply 21316 of 30918, by EduBat
I have zero experience in this but:
Best CF card in "Fixed Disk"?
Reply 21317 of 30918, by retrogamerguy1997
Recently powered back on my pentium 4 build and I couldn't shutdown windows the correct way. I suspected the disk had issues but thought It had enough time left to last till I could get a SSD as an upgrade and clone an image out of it.
Went to turn it on again today and it was stuck the boot splash thinking it was just a fluke. hit the reset button again and "disk error". Just to be sure, I hooked it up to a sata/ide to usb adapter and tried multiple usb ports on my modern pc and the disk just doesn't read. it's not a surprise given it originally was from a late 2000s intel atom machine and has been in use off and on for many years in different systems.
Otherwise though, not much retro activity going on that build these days as the gpu in the build doesn't have a fan. Haven't gotten a replacement card as I wasn't sure if I still wanted to stick with a pentium 4 or invest in a platform one generation newer. I mean for games the pentium 4 it's fine in my experience, but trying to browse the internet to download games from GOG on the build itself was not going to happen (though a bad drive doesn't help). Sure I could copy a gog installer over via a flash drive, but what's the fun in that?
On my daily driver machine, I've been playing some bit of sven co-op which is pretty retro. might also do some team fortress classic later or half-life deathmatch as for as retro games go.
Reply 21318 of 30918, by Meatball
Testing and documenting 16bit color-limited Windows (and some DOS) games. Built a Windows 98SE P4 on an ECS CS P4S5A2 (SiS XP4) w/Willamette@2.0GHz\400MHz\256KB, 512MB DDR@266MHz and various graphics cards of the day including Matrox m3D (NEC PowerVR PCX2), ATI Rage LT Pro, Obsidian 100DB-4440 SLI, Matrox Mystique 220, Diamond Stealth 3D Pro 2000 (S3 Virge DX), and Powercolor EvilKing 4 (Voodoo 4500) on a 19" Gateway VX900 CRT. Sound courtesy of Sound Blaster Live 5.1 w/SB16 emulation configured.
I was originally going with a 440BX SE440BX-2 board with Pentium III@800MHz, but I again ran into SLI problems again - the Obsidian cards (like the other Voodoo2 cards I own) plain will not work in SLI with this board.
I updated my thread with the latest results. I'm in the process at the moment of gathering additional various game patches.
Reply 21319 of 30918, by debs3759
retrogamerguy1997 wrote on 2022-03-28, 22:37:
Recently powered back on my pentium 4 build and I couldn't shutdown windows the correct way. I suspected the disk had issues but […]
I use a few apps (most free, one is paid for cos it's so useful) to clean all the garbage off my system every weekend, and do a fresh backup, so I never lose more than a week's work/play. When my main drive fails, I always have a spare waiting and a recent backup to restore onto it. Need to set up a raid array for most of my data and backups though, to stay safe, as the backups are on the same physical drive as mt data partitions (except for my drivers/manuals collection, which needs an upgrade from 3TB when I can afford it - I'm thinking of saving for 3 x 8TB in raid 5)
