First post, by 0kool
Upon first look this mainboard is almost everything I want. But every time I see chipsets covered with stickers and soldered cache my alarm goes off. I don't mind UMC, but something tells me quite a different thing might be hidden underneath.
The attachment 486board.jpg is no longer available
Reply 1 of 15, by The Serpent Rider
UMC 100%. Also fake cache.
Reply 2 of 15, by cyclone3d
I wonder if that is a board that came out of an OEM PC. I've got a couple of those boards but they have the sockets for the cache.
They are nice boards, but the soldered in cache is lame.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 15, by 0kool
Looks like it is PC Chips (M912) after all. Real UMC with likely zero level 2 cache (depending on revision). Proud of my instincts.
http://www.elhvb.com/mobokive/archive/Oldman. … Chips/specs.htm
http://www.elhvb.com/webhq/models/486vlb3/m912fake.htm
Sigh.. 😒
No idea, found it on an auction.
Thanks for your part, guys.
Reply 4 of 15, by 0kool
Looking into the matter further, I've found a similar board in an AcerMate 433s desktop, so you're probably right about the OEM thing.
The attachment acer chips.JPG is no longer available
The attachment acer desktop.JPG is no longer available
Reply 5 of 15, by keropi
an acer pc with fake cache? seems like someone did a mobo swap IMHO
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 6 of 15, by 0kool
Nah, the last one looks like M912 revision with real cache. Yep, those exist as well. You may be right, of course.
Reply 7 of 15, by The Serpent Rider
That "writeback" cache just screams fake. No way it was original board.
Reply 8 of 15, by bjwil1991
That's the PCChips M912 v1.7 with fake L2 cache. I had the M912 v1.7 with genuine L2 cache on it.
You can also remove the fake cache, solder on the sockets and jumpers for the L2 cache, install real L2 cache, and it should work, but, I believe a new BIOS chip and revision would also suffice since the one that's on there has a code on there that'll make the BIOS think there's L2 cache installed (pointing to the fake L2 cache).
Reply 9 of 15, by meljor
''Write back'' is indeed very fake cache but i think the cache on the first picture is real, they just saved pennies on the sockets.
The Acer board was swapped, no way they sold boards like that to oem's and no way Acer would burn their hands on boards with fake cache.
Reply 10 of 15, by bjwil1991
I hate to burst your bubble, but, if there aren't any jumpers for the L2 cache or sockets, it's 100% fake.
PCChips M912 v1.7 w/ Fake cache
PCChips M912 v1.7 w/ Real cache
Reply 11 of 15, by SETBLASTER
i think the original motherboard was swaped
i can't imagine a company like acer jumping into a legal battle and bad reputation for selling computers with fake cache..OR USING PCCHIPS AS a supplier for their pcs, besides acer used to build their own boards
Reply 12 of 15, by Deksor
After installing real cache on two mobos with fake cache successfully, I can say that I didn't need to change the bios at all ! It just works ^^
Reply 13 of 15, by belzrebuth
I have the same exact motherboard but it has empty sockets installed instead of fake (or real) cache.
The problem that I have with this board ( apart that I need to populate the cache) is that it only recognizes RAM installed at the 30pin sockets, if I remove those SIMMS and install a RAM module in a 72pin socket it just refuses to boot.
I checked whether there's a jumper setting for that but it should supposedly recognize any RAM configuration on its own.
Any ideas?!
Reply 15 of 15, by belzrebuth
Thanks I think that's it..
The modules I was trying were EDO but I tried some other modules that were also EDO just different make and it worked.
Since these pass the extended test should be left there or I'd better replace them with FPM type.?
