using off board fdc
First post, by andy120
how do i get a 486 to use on card fdc rather than the onboard?
Powered by one Harris 286-12
Reply 1 of 1, by Errius
Plug it in and disable the motherboard floppy controller in BIOS
You may also have to manually set the controller port/IRQ/DMA numbers if the default Plug 'n' Play values clash with those of your sound card or other cards.
"AI Requires Proof That You Are Human"
