First post, by dreamblaster
Releasing another new project : CrystalBlaster C2, based on CrystalBlaster C1
C1 was a through hole solder kit, this is a completely soldered, mostlySMT PCB version.
It has a 90s low end wavetable synthy sound, as it uses the Crystal CS9236 chip.
Available at https://www.serdashop.com/CrystalBlaster-C2
CS9236 specifications :
  • General MIDI (GM) compliant
  • 32-note polyphony at 44.1kHz rate
  • Independent reverb and chorus levels for each MIDI channel
  • 128 melodic instruments and 47 percussion sounds
Transport Tycoon Deluxe demo : https://youtu.be/PVQcIlXb5S0
Warcraft II - Orc 1 GM demo : https://youtu.be/miT54jRpUag
    50.66 KiB
    42.15 KiB
    37.04 KiB
Thanks for your support !
Reply 2 of 13, by RetroGamer4Ever
That compact design and form-factor is giving me some very bad ideas for ARM embedded system board designs that could possibly use such things as add-on hardware, to create a nice retro/arcade gaming machine.
Reply 3 of 13, by dreamblaster
Pc Sound Legacy made a video of CrystalBlaster C1 : https://youtu.be/f2-qKknAe04
This sounds the same as CrystalBlaster C2
Reply 7 of 13, by keropi
Nikita Lita wrote on 2022-04-03, 11:29:
Just curious, why the socket for the crystal chip?
machine assembly
factories do not accept old chip for assembly so having them install a socket was the best option
Reply 8 of 13, by Nikita Lita
keropi wrote on 2022-04-03, 12:37:
machine assembly
Ah hah, I see; this has been my experience with trying to get a board made as well. JLCPCB is insanely cheap but it’s SMT-only and requires you to use the parts they have in stock.
Reply 9 of 13, by dreamblaster
Socket allows to add the chips later, and swap out if they don't work. - higher success rate with factory assembly, without need for rework
That is an advantage, it does look fat though
If i ever make a successor revision, i may use tqfp which would be thinner
Reply 10 of 13, by SuperDeadite
And here's Super Street Fighter 2. If you love lo-fi synth that isn't even trying to sound realistic, this is the board for you!
I quite like it myself. 😀
https://youtu.be/EMchXcweT1A
And Fat? No no... the C2 is THICC!!!
Modules: CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster
Reply 11 of 13, by Nikita Lita
SuperDeadite wrote on 2022-04-05, 16:26:
And here's Super Street Fighter 2. If you love lo-fi synth that isn't even trying to sound realistic, this is the board for you […]
Sounds great!
Where did you get the case for the CHiLL III?
Reply 12 of 13, by SuperDeadite
Nikita Lita wrote on 2022-04-05, 16:48:
Sounds great!
It's the official Medium Size Case sold on Serdashop. XL case is also available if you plan to use larger boards like Roland/Yamaha. Note if you buy a case and CHiLL III at the same time you get a nice discount.
Reply 13 of 13, by dreamblaster
Oh it doesn't even fit the box, should make a cutout window for the chip 😀
Some of the tracks sound great ! some other... haha it is an adventurous chip,
thanks for the video !
