Reply 43760 of 58654, by appiah4
HanSolo wrote on 2022-04-07, 11:06:
appiah4 wrote on 2022-04-07, 10:25:
So I'm about to buy this mITX board because.. I'm curious. This is the only photo I have and I can't ID it. It's Probably SOME variation of the VIA EPIA line, but not one I know of. Not sure what the VT133 on the NB heatsink means but I guess it's a PLE133T? Reported as having 800MHz CPU so probably a C3 eden. Sounds like it would make a fantastic mITX DOS build with a lot of SETMUL flexibility..
For a while I was considering getting a similar tiny VIA system, too. But in the end I decided against it because I don't see much use for a retro-machine with so few slots.
How are you planning to use it?
The best use I could think of getting out of it would be to throw it into a modern mITX case and build a reverse sleeper mITX DOS PC. Sounds like a fun project but I'm pretty sure the novelty would wear off prett wast. Also not sure if that's worth doing considering I already have this:
The attachment Compaq Deskpro EN-SFF 02.jpg is no longer available
So yeah, still haven't managed to completely sell myself on the idea, don't expect me to do it for you 🤣
Reply 43761 of 58654, by HanSolo
appiah4 wrote on 2022-04-07, 11:19:
Too bad, that's what I was hoping for 😀
In fact I pretty much gave up the idea when I got my Toshiba 233MMX notebook
Reply 43762 of 58654, by imi
I'm curious if they use the audio of the CM8738 or the VT82C686A and just use the c-media as a modem.
Reply 43763 of 58654, by Nexxen
dragonerosso wrote on 2022-04-06, 21:47:
Nexxen wrote on 2022-04-03, 09:53:
Battery is beyond dead I presume? If I'm not wrong, you have to leave it 24 hrs connected to power to see if battery recovers ar […]
dragonerosso wrote on 2022-04-03, 09:21:
Just bought on ebay. Thinkpad 370c Like new esthetically but turn on display only without battery
If I'm not wrong, you have to leave it 24 hrs connected to power to see if battery recovers are is really just a dumpster thing.
Mine had a red led that stayed so, but if it turns to orange you may get some juice in it.
Beautiful machine 😉
i will try. Mine battery has a orange led when turned on, and now i'm still charging and charghing led is green. I would to change cmos and standby batteries too and check the hdd.
My battery was dead with a red led staying on.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 43764 of 58654, by HanJammer
A few items from a local trash trader... I don't even mention price I paid... but lets say it was comparable to a good business lunch.
Both machines in nice Enlight cases (the more recent case is missing the USB ports cover, but I will make one on a 3D printer). Dual socket Abit BP6 needs recap but it's supposed to work... we will see.
Reply 43765 of 58654, by H3nrik V!
HanJammer wrote on 2022-04-07, 15:21:
One of the coolest boards ever! Congrats
Reply 43766 of 58654, by Robert B
Dual Celeron stickers also on the case. BP6 FTW! 😁
The case badge: anyone want some PIE?! 😁 Don't mind if I DO! Who doesn't like pie?
Reply 43767 of 58654, by blurks
Cuttoon wrote on 2022-04-03, 19:03:
Technically, "Eastern Bloc" even includes a third of Germany.
We'd gladly give that part to Putin if he'd leave Ukraine alone.
We sincerely tried. No luck so far.
I don't believe it is up to you to speak in the name of Germany...
Reply 43768 of 58654, by Cuttoon
blurks wrote on 2022-04-07, 20:28:
You takin the piss, my dear?
Are you quite positive about that? You know me that well?
I like jumpers.
Reply 43769 of 58654, by HanJammer
H3nrik V! wrote on 2022-04-07, 15:29:
I got into PCs with SMP around 2001 with Athlon MP configurations (I still have one of the MSI boards with a dual MPs from that time) but I never had any SMP motherboard with Slot 1 / S370 CPUs. And BP6 seems quite interesting not only because it looks cool, but also the crazy idea Abit had to design it exclusively for Celerons (I've read that PIIIs were never supported in MP config on this board).
Reply 43770 of 58654, by luckybob
Cuttoon wrote on 2022-04-07, 20:57:
I'm suddenly reminded of this copy-pasta: https://knowyourmeme.com/memes/navy-seal-copypasta
God, I love the internet.
Reply 43771 of 58654, by Meatball
Since we're all recently posting about complete PC's lately, I will add a recent pickup of mine to the mix. A Voodoo3 3000 with a Dell XPS T500 wrapped around it; 768MB RAM, PIII Katmai 500MHz. Only $110.00 shipped! The seller did a great job with packing, also. Everything works. It's shown in pieces, but I've already reassembled it after a thorough cleaning. I've already added ram heatsinks and a fan to the V3 and an ES1688F w/E-Wave daughterboard to complement the onboard Yamaha YMF-724F-V. I'll also be putting the DVD-ROM aside and adding front USB ports connected to an add-in Via USB 2.0 PCI card. The Pentium III will be upgraded to a 700MHz/100 Coppermine; this is enough for the Voodoo3. RAM will be reduced to 256MB. The NIC will be removed. I am not sure if I will ever add one back; I usually don't for Win9X.
Reply 43772 of 58654, by pentiumspeed
Meatball wrote on 2022-04-07, 23:45:
Bring memory back down to 512MB, win98se does not support more than 512MB and less complicated and reliable.
Cheers,
Great Northern aka Canada.
Reply 43773 of 58654, by Meatball
pentiumspeed wrote on 2022-04-07, 23:51:
Cheers,
In all of the words I threw up, you might have missed I am reducing RAM to 256MB. I don't normally put more than that in any Win9x build.
Reply 43774 of 58654, by appiah4
Cheers,
Works perfectly fine with up to 2GB using RLoew's PATCHMEM: https://rloewelectronics.com/
Reply 43775 of 58654, by Kahenraz
I also install PATCHMEM and will sometimes add 512MB or more memory, but it's hard to find a good use case where more than 256MB actually makes a difference.
If you are still using Windows 98 as a power user and doing serious multitasking for anything other than nostalgia, then you're doing it wrong. No matter how stable it seems at any given time, one rogue application can tank the whole system and whatever "work" you had open at the time.
I'm a huge fan of DOS, 3.1, and 9x, but I remember when Windows 2000 was released as the first NT for the masses, and it was a godsend for anyone who needed to get some actual work done and play games on the same computer. Yes, there was always NT4, but it had very poor support for DirectX and many games from its time won't run on it at all.
Reply 43776 of 58654, by Joseph_Joestar
Kahenraz wrote on 2022-04-08, 07:14:
If, for some weird reason, you want to play games from 2002 and later on Win98, having 512 MB will help a bit. Morrowind and Neverwinter Nights show a slight improvement when running with 512 MB vs. 256 MB RAM for example.
I also seem to recall Diablo II: Lord of Destruction stuttering a bit less with 512 MB if you are running it in DirectDraw or Direct3D mode. That could be related to using one of the later patches though, not sure.
My retro builds
Reply 43777 of 58654, by appiah4
It makes a difference if you are dual booting a more contemporary OS such as WinXP or a modern Linux distro for convenience reasons from time to time.
Also, thanks for letting me know I am having "wrong fun". This type of attitude is never absent in any hobby, it seems.
Reply 43778 of 58654, by Cuttoon
luckybob wrote on 2022-04-07, 23:03:
The internet definitely is the best things the Romans ever did for us.
Although, tbh, I fail to get your connection between that meme and armchair patriots who fail to take an obvious joke.
Also, it's "gorilla warface", I learned that in my freshman year at counter-strike U!
While I never paid three figures for a box, I concur that, considering all components, it's probably the cheapest way to obtain a voodoo card these days...
Even if it is in the description.
I like jumpers.
Reply 43779 of 58654, by RandomStranger
I wanted a not terrible ISA sound card for a while. I found this for cheap, won the auction 2 days ago for $9 shipping included.
The attachment IMG_20220408_122933.jpg is no longer available
