First post, by Shponglefan
I'm looking to build a computer specific for retro music making both for tracker music and General MIDI.
For trackers I'm planning Scream Tracker and Impulse Tracker. I'm curious if there are other recommended trackers from that era worth exploring. Maybe FastTracker or others?
I'd also like to use this machine with General MIDI modules and GM composing. I've never composed with GM before and am curious as to what software sequencers were typically in use back then.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 1 of 7, by AppleSauce
You could try ballade for roland stuff i guess.
https://youtu.be/laRsWvnnwis
There appears to be a general midi version.
Reply 2 of 7, by Cuttoon
My CMS-401-II card came with Cakewalk 5.0.
The attachment 100_0621.JPG is no longer available
And, much to my surprise, the 3.5 floppy could still be read.
At least I could copy all files to the hard disk.
Image maker quit with an error message but that's probably insignificant.
I assume I'm not supposed to just attach the zip here but send me a PN if interested.
There also were 300 pages of manual, but those are somewhat less convenient to E-mail 😜
The attachment cakewalk_dos_5_manual.JPG is no longer available
The attachment 100_0623.JPG is no longer available
I like jumpers.
Reply 3 of 7, by SuperDeadite
For XG/GM/GM2 I like Yamaha SOL. If you are using older OS, XG Works will get you started. If you are more into Roland, Cakewalk is probably the way to go.
As a beginner myself I find Yamaha to be far easier to learn as everything is well laid out and you can learn by playing around with everything.
As for Roland, I've been trying to get a handle on using Control Messages for 88Pro's insertion effects. I've read the 250page manual several times, and sometimes I can get them to work and sometimes not...🤣.
CM-64, CM-500, SC-55MkII, SC-88 Pro, SY22, TG100, MU2000EX, PLG100-SG, PLG150-DR, PLG150-AN, SG01k, NS5R, GZ-50M, SN-U110-07, SN-U110-10, Pocket Studio 5, DreamBlaster S2, X2, McFly, E-Wave, QWave, CrystalBlaster C2, Yucatan FX, BeepBlaster, SuperOctet!
Reply 4 of 7, by Pierre32
Voyetra Sequencer.
I love this guy's "speed programming" videos using Voyetra. It's a modern studio, but he still uses Voyetra for its fast workflow.
https://youtu.be/hirugsHKXcA
Reply 6 of 7, by Shponglefan
Pierre32 wrote on 2022-04-10, 00:30:
Voyetra Sequencer.
I wonder what sort of setup he has to run older software in conjunction with what looks like an otherwise relatively modern setup?
Unfortunately, doesn't seem to have a setup/studio tour video on his channel...
Reply 7 of 7, by Pierre32
He's posted some details in the comments of various vids, iirc. I think he's just running DOSBox on a modern PC.
