Toshiba satellite 1555cds
First post, by Sphere478
Just got this cool little laptop, I wanna give it some upgrades.
It has 32mb of onboard ram,
I’d like to max out the ram, I assume that’s probably 512 or 256mb?
It comes with a k6-2 380 using 95mhz fsb
Any thoughts on how to set the fsb on this thing?
Also, how do I set the multiplier?
I’m of course gonna install a modded 570 2+ with 256k cache enabled, so gotta figure out how to set 6x100.
    1.85 MiB
Sphere's PCB projects.
Reply 1 of 21, by Sphere478
Okay, had to pull the board to investigate.
1.82 MiB
1.82 MiB
Found the means by which the multipliers are set: these three resistors(0-ohm):
1.92 MiB
If my calculations are correct: this should now be 2x (=6x)
1.58 MiB
Reply 2 of 21, by Sphere478
The voltage is already presumably at 2.0v because that’s the rating of the chip that came out.
Next: the clock gen to set the fsb.
I suspect it will be set via the three pads at the lower right. Will have to look up data sheet..
    1.7 MiB
Reply 3 of 21, by Sphere478
I couldn’t find a datasheet for this specific clock gen but I found one for one with a similar name, and this is interesting,
537.64 KiB
the multipliers were labeled w12 and this, pin 18 of the clock gen goes to a resistor labeled w2 as if it was meant to be noticed. This makes sense.
It’s got a resistor now, (0-ohm) so I will remove it.
1.48 MiB
That should presumably set the 100mhz option. Giving me a k6-3+ 600 laptop as soon as I get it back together with a cpu in it :p
My next hurdle is a bios update and ram assuming these modifications worked.
I’d also appreciate input on the fastest hard drive I can install into this as I don’t have much experience replacing 44 pin ide drives with solid state equipment. Thoughts?
Here is the datasheet I found for a similar model
https://pdf1.alldatasheet.com/datasheet-pdf/v … RESS/W215B.html
Reply 4 of 21, by Sphere478
Here are the chipsets btw
The cache is pretty crappy 10ns. The timings on it must be horrible…
Anyone know how to read video ram and cache size?
There are two of each chips
    1.37 MiB
    987.48 KiB
    908.61 KiB
    812.56 KiB
    783.68 KiB
Reply 5 of 21, by Sphere478
Of course next mod is: I need a k6-3+ 570 to use.
So I move the resistor on the 2+ 570 to here:
1.25 MiB
All modded with IHS reinstalled
    1.63 MiB
Reply 6 of 21, by Sphere478
1.51 MiB
Looks like my resistor tricks were on point!
Next upgrades:
-What’s the biggest memory stick I can get?
-What’s the best display to upgrade to?
-What’s the fastest hard drive that will fit on the 144 pin?
Reply 7 of 21, by Sphere478
I ordered these
A ssd 144 pin 128gb
I think this chipset probably has the 128gb limit, though I am not sure.
And 512mb seems to be about as big as these sd sticks come, hopefully this chipset’s memory controller is up to it..
Reply 8 of 21, by Sphere478
According to this it seems I have 512k of cache (bummer, but expected)
86.16 KiB
And 2mb of video memory, damn….. that hurts 🤣
67.32 KiB
Wonder if it would be possible to upgrade any of that…?🤔 soldering wouldn’t be too hard for the sgram but the cache, one of them is inside the socket.
Reply 9 of 21, by Sphere478
I keep having issues with the laptop locking up, I think heat may be a issue,
But until now I’ve been kinda blind as I didn’t have windows installed, now I’ll try playing with setmul, and central tweaking unit and speedfan to see if I can get to the bottom of this.
Reply 10 of 21, by Sphere478
$RRG1RVX.zip
680.81 KiB
28 downloads
updated bios!
1.85 MiB
Still having stability issues can’t pass a super pi even at 500 mhz
But it does seem
Better with the new bios. Windows seems not to crash as easily and with out a external fan. Testing continues..
Speedfan isn’t detecting anything.
Reply 11 of 21, by Sphere478
I popped the processor out and tried it out in another setup, my stability issues seem to have been the processor it’s self
Reply 12 of 21, by tauro
Remarkable job. Respect!
That's a fine laptop for Win98/DOS.
I've dealt with quite a few Toshibas.
The only thing I don't like about them is the screen stretching because it deforms the pixels unless you are running the LCD at the highest resolution
Reply 13 of 21, by Sphere478
The processor was definitely the issue, it’s actually a rare result not to get a good unlock on a 570. In the thread about that unlock many people have unlocked them, this is the first to fail that I know of.
Failed unlocks on lower clock models are common though. The 570s were high grade chips.
Oh well.
Reply 14 of 21, by Sphere478
I have a update. I was wrong, the processor was fine, what convinced me otherwise was a string of failed super pi tests on my other systems. That started around around the time I tested this cpu on one of them. I still have no idea why that happened.
But I was able to replicate those failed tests on known good cpus.
So anyway, I believe now that the cpu was overheating. So I will likely have to underclock/undervolt the cpu. Or beef up the cooling. And/or bin a super good cpu specimen
I will try again to get this laptop all upgraded and stable at some point soon.
I have received now a 128gb ide ssd for it in the meantime 😀
Reply 15 of 21, by bakemono
1555CDS overheated and ran unstable on the stock CPU. I had one in college and had to run it at 190MHz low speed to be able to get anything done without constant crashing. The problem was the extremely conservative fan operation, maybe it was a BIOS/ACPI issue. The RAM can go up to 160MB at least.
again another retro game on itch: https://90soft90.itch.io/shmup-salad
Reply 16 of 21, by Sphere478
Are you for sure that a 256 mb stick won’t work?
Reply 18 of 21, by Sphere478
bakemono wrote on 2022-08-14, 20:20:
Can't say, as I never tried a 256MB stick.
If you have one, give it a try real quick 😀
