Theme Park
First post, by Orchestration
I have just got DOSBox and am trying to run Theme Park however it seems to be running very fast, I can barely do anything, years shot by in a few mins and then I lose.
Is there a way yo slow the game down?
Reply 1 of 1, by abyss
Here is what i did with dosbox. I changed core=auto to dynamic and cycles=auto to 3000 in the dosbox conf file. If it's a protected mode game go to 6000 cycles with ctrl-f12 in dosbox. Just look through the game files and if a file says dos4gw then you know it's a protected mode game. Adjust cycles by ctrl f-11 which is to lower cycles and ctrl f-12 to increase cycles to get the perfect speed. Don't use the default cycles=auto setting as a lot of the it uses more cycles then you need to run the game. The cycles=auto setting tried to use more cycles than my computer can handle. All i need to run quake 1 is 6000 cycles and dynamic mode and 10 frameskip. If you have a slower computer you can also use frameskips which also increase speed by ctrl f-7 and ctrl f-8.
