First post, by Jackhead
I like to install Arx Libertatis 1.2.1 on a winXP (32bit) system.
So i installed Arx Fatalis from cd, update to latest patch and install Arx Libertatis. After that the Game crash on startup. The arx.log say that it cant find the pak data files. But they in the game dir. I also checks the dir in regedit.
Anyone had same problems and have a solution for this?
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - A5x86 X5 P75 - 64MB - AHA-2842A VLB - ET4000W32P VLB - CT2230 - GUS ACE - MPU-401AT with YucatanFX
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 3, by DosFreak
Supposedly v1.3 restored XP support, previously you had to use v1.1.2, although using CF explorer on v1.22 and above and changing OS subsystem appeared to work fine for getting it to work on XP.
https://arx-libertatis.org/files/snapshots/ar … 22-03-27/README
- Restored Windows XP support
https://wiki.arx-libertatis.org/Development_s … hots#Windows_XP
Make your games work offline
Reply 2 of 3, by Jackhead
thanks it work now 👍🏻
Reply 3 of 3, by Jackhead
DosFreak wrote on 2022-04-17, 02:24:
Supposedly v1.3 restored XP support, previously you had to use v1.1.2, although using CF explorer on v1.22 and above and changin […]
I tryed a v1.3 version. where i have to change the subsystem and what value?
I installed cfexplorer and edit the exe under optional Header/ Subsystem value are Windows Gui, you point on that value ?
Or is it maybe possible to update from 1.1.2 to latest version without using the installer?
