First post, by Maccas
 - Newbie
Hey, I'm running win98se and whenever I restart in dos mode I am met with a blank screen (no display, screen still thinks it's on). When I start up normally there are no problems with mouse/sound/cd drivers so assume the problem is in the config.sys file if it is an error on my part. My config.sys file contains the lines
REM --- DOS STARTUP CONFIG.SYS - DEFAULT ---
DOS=HIGH,UMB
DEVICEHIGH=C:\oakcdrom.sys /D:MSCD001
DEVICEHIGH=C:\WINDOWS\HIMEM.SYS
DEVICEHIGH=C:\WINDOWS\EMM386.EXE RAM I=B000-B7FF
BUFFERS=20
FILES=20
(taken from snover's 2doswin)
This is the first time I have ever had problems with dos in win98, the problems have started with the last format, any help would be greatly appreciated.
