Reply 21540 of 30481, by Tetrium
- l33t++
Turbo -> wrote on 2022-04-23, 12:10:I've made a bracket - stand; I don't know how else would I name it, to prevent my graphics card from bending too much, due to quite heavy passive heatsink. It was time-consuming, but I like the result in my Windows XP build.
I kinda like this solution 🙂
I'd be a little bit more worried about it having sharp edges though. If it has any I'd definitely file those down if only to prevent it cutting any wires (and your flesh 😋).
PcBytes wrote on 2022-04-23, 14:28:I didn't desolder it. Just followed @Robert B's guide from here: Re: Hello, World! :D - Robert B's PC builds - oogle away freely […]
Kahenraz wrote on 2022-04-23, 14:13:Well done. How hard was it to desolder the socket?
Re: Hello, World! :D - Robert B's PC builds - oogle away freely :)
In my case though, the socket proved a bit tighter than the original ECS socket after installing.
Currently has a Duron 1100 (I think?) and 256MB of RAM in it as I plan on doing a ceramic AMD build for once (Morgan core btw!), hopefully the ever so slightly chipped core won't cause me horrible issues.All in all, this could be a positive "warning" 🤣 - things will get crazier by each day for me, now that I'm fully recovered after a rather severe enterocolitis. Anything goes, from replacing Skt462 sockets to doing Tualeron mods on the cheap.
I knew the top part of the CPU socket could be removed (I repaired a couple boards with broken levers this way), but the thought never had occurred to me that the bottom part of the CPU socket wasn't, like, glued to the PCB or something. I'm definitely gonna remember this one 😀
