First post, by red-ray
- l33t
I now need to know the PCI ID and Chipset ID of a G71 GeForce 7800 GS+ AGP, screen shots similar to as below would be ideal.
I decided I needed a newer AGP NVidia GeForce GPU and decided to get a BFG GeForce 7800 GS OC - 256 MB GDDR3 256 bit AGP and now need to decide which system to install it in. As it's a 1.5 Volt AGP 3.0 card I suspect this will limit my options. I am considering:
Gigabyte 8IPE775 Pro - Intel 82865PE Chipset + Intel Pentium 4 640 (Prescott 2M) 3.20GH - I think this should be OKASUS PC-DL - Intel 82875P Chipset + 2 x Intel Xeon (Gallatin) 3.20GHz - I think this should be OKTYAN S2466 Tiger MPX - AMD 762 SMP Chipset + AMD Athlon MP 2400+ (Thoroughbred) 2.00GHz - this is only AGP V2 and I don't think it will work.
What are your thoughts on which would work and if you have a GeForce 7800GS AGP which motherboard do you use it in please?
