First post, by ]--Freeman--[
Hi people!
I have installed the gus driver from the dosbox wiki gus guide and all works except for windows 3.11. In windows 3.11 I have installed Torin's Passage. When I run it, it works but the sound is choppy. Before installing GUS, I had soundblaster 16 drivers for windows and the game worked perfectly. Both have different irqs. For this reason I don't think it is a conflict between the soundcards. I've modified the blocksize in dosbox.conf but it hasn't worked .
I don't know how to solve it, can you help me please?
Thanks a lot!!
Reply 2 of 4, by ]--Freeman--[
Because I only found the windows version. It was very difficult to find it 🙁
Reply 3 of 4, by tannerstevo
If your disk is the same as mine, it should have both the windows and dos versions. Check the disk to see if it has install.bat, if it does you should be able to install the dos version.
Reply 4 of 4, by ]--Freeman--[
Yes, you are right ^^. I've just checked it and it has dos version too and, installing it, I've noticed that doesn't have gus option in the audio config. May be the sound is choppy for this reason in windows 3.11 because it is configured with gus currently. In dos, it works great!! 😁
Thank you!!!
