First post, by lloydey
Hi
I have just downloaded DosBox (0.70) and have installed it successfully on Windows Vista. Without changing any settings (exept to run it in full screen mode) I have managed to successfully play Theme Hospital (which uses Dos4gw and will not run directly through Vista).
Unfortunately I am having video problems - the colours appear patchy and often there are grey spots on the screen. I have a ATi Mobility with 128mb of dedicated video memory, on a 2ghz laptop with 2gb RAM.
Any ideas about how to set up the video correctly would be appreciated. I have tried searching for relevant topics but cannot find any answers in relation to video generally or theme hospital specifically.
If you need any more info then let me know.
Thanks in advance
Tom
